Real-ESRGAN-x4plus Example
This document describes using the QAI AppBuilder Python API to run inference with the Real-ESRGAN-x4plus super-resolution model on the Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
Run the script​
    cd qai-appbuilder/samples
  • Prepare input data (the sample provides a default image)
input image
Run inference
warning
On QCS6490 / SC8280XP, do not use the default float DLC. The default .dlc path fails with The SocModel doesn't support FP16. Use --bin to download the precompiled HTP context binary.
python3 ComputerVision/Super_Resolution/real_esrgan_x4plus/real_esrgan_x4plus.py --chipset 9075 --no_show
On QCS9075 the Hub default is a .bin HTP context that runs as-is. Use --no_show on headless sessions.
--no_show avoids opening an image viewer on headless SSH sessions.
Expected result​
A successful run writes:
ComputerVision/Super_Resolution/real_esrgan_x4plus/output.png
Launcher alternative:
python3 run_inference.py --model real_esrgan_x4plus --args "--chipset 6490 --bin --no_show"
