Unet-Segmentation Example
This document explains how to use the QAI AppBuilder Python API to perform inference with the Unet-Segmentation image segmentation model using the Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
Run the script​
    cd qai-appbuilder/samples
Input image
  • Run inference
    python3 ComputerVision/Semantic_Segmentation/unet_segmentation/unet_segmentation.py --chipset 9075
  • Example result
Output image
The first run downloads the model via Qualcomm® AI Hub (network-dependent). You can also use the launcher from samples:
python3 run_inference.py --model unet_segmentation --args "--chipset 9075"
