Whisper-Base Example
This document explains how to use the QAI AppBuilder Python API to perform inference with the Whisper-Base speech recognition model using the Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
pip3 install requests tqdm qai-hub py3-wget Pillow torch torchvision opencv-python-headless audio2numpy
Run the script​
    cd qai-appbuilder/samples
input audio
  • Run inference
    python3 audio/Speech_Recognition/whisper_base_en/whisper_base_en.py --chipset 9075
The default input is the bundled jfk.wav. On success the terminal prints a transcription such as:
Transcription: And so my fellow Americans, ask not what your country can do for you, ask what you can do for your country.
The first run downloads encoder/decoder models via Qualcomm® AI Hub. Decoding needs the tiktoken vocabulary; if the device cannot reach openaipublic.blob.core.windows.net, pre-warm tiktoken.get_encoding("gpt2") on a machine with network access.
python3 run_inference.py --model whisper_base_en --args "--chipset 9075"
