YOLOv8-det Example
This document describes using the QAI AppBuilder Python API to run inference with the YOLOv8-det object detection model on the Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
Run the script​
    cd qai-appbuilder/samples
  • Prepare input data (use the bundled sample input when available)
input image
Fix output order (required on QCS6490 / SC8280XP / QCS9075)​
Verified on Dragon Q6A (--chipset 6490) and AIRbox Q900 (--chipset 9075): AI Hub packages often use this layout:
Output indexShapeMeaning
0[1, 8400]scores
1[1, 8400]class_idx
2[1, 8400, 4]boxes
Upstream yolov8_det.py assumes [boxes, scores, class_idx], which leads to an NMS failure:
IndexError: index ... is out of bounds for dimension 0 with size ...
Before running, update the output parsing in Inference() inside ComputerVision/Object_Detection/yolov8_det/yolov8_det.py (back up the file first).
Replace:
    # Run the inference.
model_output = yolov8.Inference(image)
pred_boxes = torch.tensor(model_output[0].reshape(1, -1, 4))
pred_scores = torch.tensor(model_output[1].reshape(1, -1))
pred_class_idx = torch.tensor(model_output[2].reshape(1, -1))
with:
# Output layout differs by model package:
# - some packages: [boxes, scores, class_idx]
# - QCS6490 / QCS9075 hub packages often: [scores, class_idx, boxes]
import numpy as _np
a0, a1, a2 = _np.array(model_output[0]), _np.array(model_output[1]), _np.array(model_output[2])
if a2.ndim == 3 and a2.shape[-1] == 4:
pred_scores = torch.tensor(a0.reshape(1, -1))
pred_class_idx = torch.tensor(a1.reshape(1, -1))
pred_boxes = torch.tensor(a2.reshape(1, -1, 4))
else:
pred_boxes = torch.tensor(a0.reshape(1, -1, 4))
pred_scores = torch.tensor(a1.reshape(1, -1))
pred_class_idx = torch.tensor(a2.reshape(1, -1))
This auto-selects the layout when the last tensor is [..., 4], and keeps compatibility with 6490 / 9075 and other packages.
Run inference​
python3 ComputerVision/Object_Detection/yolov8_det/yolov8_det.py --chipset 9075
Expected result​
After the output-order fix, a successful run on QCS6490 or QCS9075 writes:
ComputerVision/Object_Detection/yolov8_det/output.png
Without a display, Error: no DISPLAY environment variable specified may appear; ignore it if output.png exists and the exit code is 0.
  • Example result (illustrative; actual result depends on the input and model package)
output image
Launcher alternative (still apply the output-order fix first):
python3 run_inference.py --model yolov8_det --args "--chipset 6490"
# or on QCS9075:
# python3 run_inference.py --model yolov8_det --args "--chipset 9075"
