QAIRT SDK Install
The QAIRT (Qualcomm® AI Runtime) SDK is a software package that integrates Qualcomm® AI software products, including Qualcomm® AI Engine Direct, Qualcomm® Neural Processing SDK, and Qualcomm® Genie. QAIRT provides developers with all the necessary tools for porting and deploying AI models on Qualcomm® hardware accelerators, along with the runtime for running models on CPU, GPU, and NPU.
Currently, the QAIRT SDK supports model porting for Pytorch, TensorFlow, TFLite, and ONNX frameworks.
Supported inference hardware accelerators: CPU, GPU, NPU.
QAIRT SDK Architecture
QAIRT SDK System Requirements
  • 64-bit x86 processor
  • Ubuntu 22.04
  • Python 3.10
Download QAIRT SDK Package​
info
Please use QAIRT SDK version 2.42.0.251225
X86 Linux PC
export QAIRT_VERSION=2.42.0.251225
  • Download the 2.42.0.251225 QAIRT SDK from Qualcomm® Software Center
    X86 Linux PC / Qualcomm Device
    wget https://softwarecenter.qualcomm.com/api/download/software/sdks/Qualcomm_AI_Runtime_Community/All/${QAIRT_VERSION}/v${QAIRT_VERSION}.zip
  • Extract the QAIRT SDK package
    unzip v${QAIRT_VERSION}.zip
    cd qairt/${QAIRT_VERSION}
Configure QAIRT Environment​
Create Python Environment​
QAIRT requires a Python 3.10 environment. Users can create one using Anaconda.
After installing Anaconda, create and activate a Python 3.10 environment using the terminal:
X86 Linux PC
conda create -n qairt python=3.10
conda activate qairt
Configure QAIRT Environment Variables​
X86 Linux PC
source bin/envsetup.sh
Check Dependencies​
  • Check library dependencies
    X86 Linux PC
    sudo ${QAIRT_SDK_ROOT}/bin/check-linux-dependency.sh
    Checking for libncurses5
    Checking for libgl1
    Checking for libgtk-3-dev
    Checking for libasound2-dev
    Checking for libnss3
    Checking for git
    Checking for nodejs
    Checking for npm
    Checking for libgbm-dev
    Checking for desktop-file-utils
    Checking for python3-dev
    Checking for python3-pip
    Checking for python3-setuptools
    Checking for clang
    Checking for libc++-dev
    Checking for libc++abi-dev
    Checking for flatbuffers-compiler
    Checking for libflatbuffers-dev
    Checking for rename
    All Dependency Packages Found
    Done!!
  • Check Toolchain Dependencies
    X86 Linux PC
    ${QAIRT_SDK_ROOT}/bin/envcheck -c
    Checking Clang Environment
    [INFO] Found clang++ at /usr/bin/clang++
  • Install Python Library Dependencies
    X86 Linux PC
    python3 "${QAIRT_SDK_ROOT}/bin/check-python-dependency"
Install AI Frameworks​
Select the model framework libraries to install based on your business model format. It's not necessary to install all of them.
Package NameVersion
TensorFlow2.10.1
TFLite2.3.0
PyTorch1.13.1
ONNX1.16.1
ONNX Runtime1.17.1
ONNX Simplifier0.4.36
Complete SDK Documentation​
The QAIRT SDK integrates Qualcomm® AI Engine Direct (QNN), Qualcomm® Neural Processing SDK (SNPE), and Qualcomm® Genie (Genie). The detailed documentation is available at the following locations:
Local Documentation
  • qairt/2.42.0.251225/docs/QNN
  • qairt/2.42.0.251225/docs/SNPE
  • qairt/2.42.0.251225/docs/Genie
Online Documentation
ARM64 Docker Image​
Radxa provides a Docker image for using the QAIRT SDK on the board. Alternatively, you can follow the instructions in this document to install it manually.
  • Install Docker
    Refer to Docker Usage for Docker installation instructions
  • Pull the Docker image
    sudo docker pull radxazifeng278/qairt-npu-9075:v1.1
    • Run the Docker image
    sudo docker run --privileged -it -v /dev:/dev -v $(pwd):/workspace --name qairt-sdk radxazifeng278/qairt-npu-9075:v1.1 /bin/bash
    Note: In the radxazifeng278/qairt-npu-9075:v1.1 image, the QAIRT directory is located at /root/qairt. If you are unsure after entering the container, confirm it with:
    find / -name "qairt"
