QAIRT CLI Tools
This document describes the usage of the main CLI tools used in QAIRT SDK for model porting and deployment.
CLI Tools Table
CLI Tool NamePurpose
qairt-converterConvert DLC models
qairt-quantizerQuantize DLC models
qnn-context-binary-generatorConvert Context Binary models
qnn-net-runInference for DLC/Context Binary models
qnn-context-binary-utilityInspect Context Binary models
CLI Tools
qairt-converter
The qairt-converter tool converts models from Onnx, TensorFlow, TFLite, and PyTorch frameworks into DLC files in QNN graph format. The qairt-converter automatically detects the framework based on the source model's file extension. The current ONNX conversion supports up to ONNX Opset 21.
usage: qairt-converter [--source_model_input_shape INPUT_NAME INPUT_DIM]
[--out_tensor_node OUT_NAMES]
[--source_model_input_datatype INPUT_NAME INPUT_DTYPE]
[--source_model_input_layout INPUT_NAME INPUT_LAYOUT]
[--desired_input_layout INPUT_NAME DESIRED_INPUT_LAYOUT]
[--source_model_output_layout OUTPUT_NAME OUTPUT_LAYOUT]
[--desired_output_layout OUTPUT_NAME DESIRED_OUTPUT_LAYOUT]
[--desired_input_color_encoding ...]]
[--preserve_io_datatype [PRESERVE_IO_DATATYPE ...]]
[--dump_config_template DUMP_IO_CONFIG_TEMPLATE] [--config IO_CONFIG]
[--dry_run [DRY_RUN]] [--enable_framework_trace] [--gguf_config GGUF_CONFIG]
[--quantization_overrides QUANTIZATION_OVERRIDES]
[--lora_weight_list LORA_WEIGHT_LIST]
[--quant_updatable_mode {none,adapter_only,all}] [--onnx_skip_simplification]
[--onnx_override_batch BATCH] [--onnx_define_symbol SYMBOL_NAME VALUE]
[--onnx_validate_models] [--onnx_summary]
[--onnx_perform_sequence_construct_optimizer] [--tf_summary]
[--tf_override_batch BATCH] [--tf_disable_optimization]
[--tf_show_unconsumed_nodes] [--tf_saved_model_tag SAVED_MODEL_TAG]
[--tf_saved_model_signature_key SAVED_MODEL_SIGNATURE_KEY]
[--tf_validate_models] [--tflite_signature_name SIGNATURE_NAME]
[--dump_exported_onnx] --input_network INPUT_NETWORK [--debug [DEBUG]]
[--output_path OUTPUT_PATH] [--copyright_file COPYRIGHT_FILE]
[--float_bitwidth FLOAT_BITWIDTH] [--float_bias_bitwidth FLOAT_BIAS_BITWIDTH]
[--set_model_version MODEL_VERSION] [--export_format EXPORT_FORMAT]
[--converter_op_package_lib CONVERTER_OP_PACKAGE_LIB]
[--package_name PACKAGE_NAME | --op_package_config CUSTOM_OP_CONFIG_PATHS [CUSTOM_OP_CONFIG_PATHS ...]]
[-h] [--target_backend BACKEND] [--target_soc_model SOC_MODEL]
required arguments:
--input_network INPUT_NETWORK, -i INPUT_NETWORK
Path to the source framework model.
optional arguments:
--source_model_input_shape INPUT_NAME INPUT_DIM, -s INPUT_NAME INPUT_DIM
The name and dimension of all the input buffers to the network specified in
the format [input_name comma-separated-dimensions],
for example: --source_model_input_shape 'data' 1,224,224,3.
Note that the quotes should always be included in order to handle special
characters, spaces, etc.
NOTE: Required for TensorFlow and PyTorch. Optional for Onnx and Tflite
In case of Onnx, this feature works only with Onnx 1.6.0 and above
--out_tensor_node OUT_NAMES, --out_tensor_name OUT_NAMES
Name of the graph's output Tensor Names. Multiple output names should be
provided separately like:
--out_tensor_name out_1 --out_tensor_name out_2
NOTE: Required for TensorFlow. Optional for Onnx, Tflite and PyTorch
The names and datatype of the network input layers specified in the format
[input_name datatype], for example:
'data' 'float32'
Default is float32 if not specified
Note that the quotes should always be included in order to handlespecial
For multiple inputs specify multiple --source_model_input_datatype on the
command line like:
--source_model_input_datatype 'data1' 'float32'
--source_model_input_datatype 'data2' 'float32'
Layout of each input tensor. If not specified, it will use the default based
on the Source Framework, shape of input and input encoding.
Accepted values are-
NCDHW, NDHWC, NCHW, NHWC, HWIO, OIHW, NFC, NCF, NTF, TNF, NF, NC, F
N = Batch, C = Channels, D = Depth, H = Height, W = Width, F = Feature,
T = Time, I = Input, O = Output
NDHWC/NCDHW used for 5d inputs
NHWC/NCHW used for 4d image-like inputs
HWIO/IOHW used for Weights of Conv Ops
NFC/NCF used for inputs to Conv1D or other 1D ops
NTF/TNF used for inputs with time steps like the ones used for LSTM op
NF used for 2D inputs, like the inputs to Dense/FullyConnected layers
NC used for 2D inputs with 1 for batch and other for Channels (rarely used)
F used for 1D inputs, e.g. Bias tensor
For multiple inputs specify multiple --source_model_input_layout on the
command line.
Eg:
--source_model_input_layout "data1" NCHW --source_model_input_layout
"data2" NCHW
Desired Layout of each input tensor. If not specified, it will use the
default based on the Source Framework, shape of input and input encoding.
For multiple inputs specify multiple --desired_input_layout on the command
line.
Eg:
--desired_input_layout "data1" NCHW --desired_input_layout "data2" NCHW
Layout of each output tensor. If not specified, it will use the default
N = Batch, C = Channels, D = Depth, H = Height, W = Width, F = Feature, T =
Time
For multiple inputs specify multiple --source_model_output_layout on the
command line.
Eg:
--source_model_output_layout "data1" NCHW --source_model_output_layout
"data2" NCHW
Desired Layout of each output tensor. If not specified, it will use the
default based on the Source Framework.
Time
NDHWC/NCDHW used for 5d outputs
NHWC/NCHW used for 4d image-like outputs
NFC/NCF used for outputs to Conv1D or other 1D ops
NTF/TNF used for outputs with time steps like the ones used for LSTM op
NF used for 2D outputs, like the outputs to Dense/FullyConnected layers
NC used for 2D outputs with 1 for batch and other for Channels (rarely used)
F used for 1D outputs, e.g. Bias tensor
For multiple outputs specify multiple --desired_output_layout on the command
line.
Eg:
--desired_output_layout "data1" NCHW --desired_output_layout "data2"
NCHW
--desired_input_color_encoding ...], -e ...]
Usage: --input_color_encoding "INPUT_NAME" INPUT_ENCODING_IN
[INPUT_ENCODING_OUT]
Input encoding of the network inputs. Default is bgr.
e.g.
--input_color_encoding "data" rgba
Quotes must wrap the input node name to handle special characters,
spaces, etc. To specify encodings for multiple inputs, invoke
--input_color_encoding for each one.
e.g.
--input_color_encoding "data1" rgba --input_color_encoding "data2" other
Optionally, an output encoding may be specified for an input node by
providing a second encoding. The default output encoding is bgr.
e.g.
--input_color_encoding "data3" rgba rgb
Input encoding types:
image color encodings: bgr,rgb, nv21, nv12, ...
time_series: for inputs of rnn models;
other: not available above or is unknown.
Supported encodings:
bgr
rgb
rgba
argb32
nv21
nv12
Use this option to preserve IO datatype. The different ways of using this
option are as follows:
--preserve_io_datatype <space separated list of names of inputs and
outputs of the graph>
e.g.
--preserve_io_datatype input1 input2 output1
The user may choose to preserve the datatype for all the inputs and outputs
of the graph.
Note: --config gets higher precedence than --preserve_io_datatype.
Dumps the yaml template for I/O configuration. This file can be edited as
per the custom requirements and passed using the option --configUse this
option to specify a yaml file to which the IO config template is dumped.
--config IO_CONFIG Use this option to specify a yaml file for input and output options.
--dry_run [DRY_RUN] Evaluates the model without actually converting any ops, and returns
unsupported ops/attributes as well as unused inputs and/or outputs if any.
Use this option to enable converter to trace the op/tensor change
information.
Currently framework op trace is supported only for ONNX converter.
This is an optional argument that can be used when input network is a GGUF
File.It specifies the path to the config file for building GenAI model.(the
config.json file generated when saving the huggingface model)
--debug [DEBUG] Run the converter in debug mode.
--output_path OUTPUT_PATH, -o OUTPUT_PATH
Path where the converted Output model should be saved.If not specified, the
converter model will be written to a file with same name as the input model
Path to copyright file. If provided, the content of the file will be added
to the output model.
Use the --float_bitwidth option to convert the graph to the specified float
bitwidth, either 32 (default) or 16.
Use the --float_bias_bitwidth option to select the bitwidth to use for float
bias tensor, either 32 or 16 (default '0' if not provided).
User-defined ASCII string to identify the model, only first 64 bytes will be
stored
DLC_DEFAULT (default)
- Produce a Float graph given a Float Source graph
- Produce a Quant graph given a Source graph with provided Encodings
DLC_STRIP_QUANT
- Produce a Float Graph with discarding Quant data
-h, --help show this help message and exit
Custom Op Package Options:
--converter_op_package_lib CONVERTER_OP_PACKAGE_LIB, -cpl CONVERTER_OP_PACKAGE_LIB
Absolute path to converter op package library compiled by the OpPackage
generator. Must be separated by a comma for multiple package libraries.
Note: Order of converter op package libraries must follow the order of xmls.
Ex1: --converter_op_package_lib absolute_path_to/libExample.so
Ex2: -cpl absolute_path_to/libExample1.so,absolute_path_to/libExample2.so
--package_name PACKAGE_NAME, -p PACKAGE_NAME
A global package name to be used for each node in the Model.cpp file.
Defaults to Qnn header defined package name
--op_package_config CUSTOM_OP_CONFIG_PATHS [CUSTOM_OP_CONFIG_PATHS ...], -opc CUSTOM_OP_CONFIG_PATHS [CUSTOM_OP_CONFIG_PATHS ...]
Path to a Qnn Op Package XML configuration file that contains user defined
custom operations.
Quantizer Options:
--quantization_overrides QUANTIZATION_OVERRIDES, -q QUANTIZATION_OVERRIDES
Use this option to specify a json file with parameters to use for
quantization. These will override any quantization data carried from
conversion (eg TF fake quantization) or calculated during the normal
quantization process. Format defined as per AIMET specification.
LoRA Converter Options:
Path to a file specifying a list of tensor names that should be updateable.
Specify whether/for which tensors the quantization encodings change across
use-cases. In none mode, no quantization encodings are updatable. In
adapter_only mode quantization encodings for only lora/adapter branch
(Conv->Mul->Conv) change across use-case, the base branch quantization
encodings remain the same. In all mode, all quantization encodings are
updatable.
Onnx Converter Options:
--onnx_skip_simplification, -oss
Do not attempt to simplify the model automatically. This may prevent some
models from
properly converting when sequences of unsupported static operations are
present.
The batch dimension override. This will take the first dimension of all
inputs and treat it as a batch dim, overriding it with the value provided
here. For example:
--onnx_override_batch 6
will result in a shape change from [1,3,224,224] to [6,3,224,224].
If there are inputs without batch dim this should not be used and each input
should be overridden independently using -d option for input dimension
overrides.
This option allows overriding specific input dimension symbols. For instance
you might see input shapes specified with variables such as :
data: [1,3,height,width]
To override these simply pass the option as:
--onnx_define_symbol height 224 --onnx_define_symbol width 448
which results in dimensions that look like:
data: [1,3,224,448]
Validate the original ONNX model against optimized ONNX model.
Constant inputs with all value 1s will be generated and will be used
by both models and their outputs are checked against each other.
The % average error and 90th percentile of output differences will be
calculated for this.
Note: Usage of this flag will incur extra time due to inference of the
models.
--onnx_summary Summarize the original onnx model and optimized onnx model.
Summary will print the model information such as number of parameters,
number of operators and their count, input-output tensor name, shape and
dtypes.
This option allows optimization on SequenceConstruct Op.
When SequenceConstruct op is one of the outputs of the graph, it removes
SequenceConstruct op and makes its inputs as graph outputs to replace the
original output of SequenceConstruct.
--tf_summary Summarize the original TF model and optimized TF model.
dtypes.
TensorFlow Converter Options:
here. For example:
--tf_override_batch 6
will result in a shape change from [1,224,224,3] to [6,224,224,3].
should be overridden independently using -s option for input dimension
overrides.
Do not attempt to optimize the model automatically.
Displays a list of unconsumed nodes, if there any are found. Nodeswhich are
unconsumed do not violate the structural fidelity of thegenerated graph.
Specify the tag to seletet a MetaGraph from savedmodel. ex:
--saved_model_tag serve. Default value will be 'serve' when it is not
assigned.
Specify signature key to select input and output of the model. ex:
--tf_saved_model_signature_key serving_default. Default value will be
'serving_default' when it is not assigned
--tf_validate_models Validate the original TF model against optimized TF model.
models.
Tflite Converter Options:
Use this option to specify a specific Subgraph signature to convert
PyTorch Converter Options:
--dump_exported_onnx Dump the exported Onnx model from input Torchscript model
Backend Options:
Use this option to specify the backend on which the model needs to run.
Providing this option will generate a graph optimized for the given backend
and this graph may not run on other backends. The default backend is HTP.
Supported backends are CPU,GPU,DSP,HTP,HTA,LPAI.
Use this option to specify the SOC on which the model needs to run.
This can be found from SOC info of the device and it starts with strings
such as SDM, SM, QCS, IPQ, SA, QC, SC, SXR, SSG, STP, QRB, or AIC.
NOTE: --target_backend option must be provided to use --target_soc_model
option.
Note: Only one of: {'package_name', 'op_package_config'} can be specified Note: Only one of:
qairt-quantizer
qairt-quantizer tool converts non-quantized DLC models to quantized DLC models.
usage: qairt-quantizer --input_dlc INPUT_DLC [--output_dlc OUTPUT_DLC] [--input_list INPUT_LIST]
[--enable_float_fallback] [--apply_algorithms ALGORITHMS [ALGORITHMS ...]]
[--bias_bitwidth BIAS_BITWIDTH] [--act_bitwidth ACT_BITWIDTH]
[--weights_bitwidth WEIGHTS_BITWIDTH] [--float_bitwidth FLOAT_BITWIDTH]
[--float_bias_bitwidth FLOAT_BIAS_BITWIDTH] [--ignore_quantization_overrides]
[--use_per_channel_quantization] [--use_per_row_quantization]
[--enable_per_row_quantized_bias]
[--use_native_input_files] [--use_native_output_files]
[--restrict_quantization_steps ENCODING_MIN, ENCODING_MAX]
[--keep_weights_quantized] [--adjust_bias_encoding]
[--act_quantizer_calibration ACT_QUANTIZER_CALIBRATION]
[--param_quantizer_calibration PARAM_QUANTIZER_CALIBRATION]
[--act_quantizer_schema ACT_QUANTIZER_SCHEMA]
[--param_quantizer_schema PARAM_QUANTIZER_SCHEMA]
[--percentile_calibration_value PERCENTILE_CALIBRATION_VALUE]
[--use_aimet_quantizer] [--op_package_lib OP_PACKAGE_LIB]
[--dump_encoding_json] [--config CONFIG_FILE] [--export_stripped_dlc] [-h]
[--target_backend BACKEND] [--target_soc_model SOC_MODEL] [--debug [DEBUG]]
required arguments:
--input_dlc INPUT_DLC, -i INPUT_DLC
Path to the dlc container containing the model for which fixed-point
encoding metadata should be generated. This argument is required
optional arguments:
--output_dlc OUTPUT_DLC, -o OUTPUT_DLC
Path at which the metadata-included quantized model container should be
written.If this argument is omitted, the quantized model will be written at
<unquantized_model_name>_quantized.dlc
--input_list INPUT_LIST, -l INPUT_LIST
Path to a file specifying the input data. This file should be a plain text
file, containing one or more absolute file paths per line. Each path is
expected to point to a binary file containing one input in the "raw" format,
ready to be consumed by the quantizer without any further preprocessing.
Multiple files per line separated by spaces indicate multiple inputs to the
network. See documentation for more details. Must be specified for
quantization. All subsequent quantization options are ignored when this is
not provided.
--enable_float_fallback, -f
Use this option to enable fallback to floating point (FP) instead of fixed
point.
This option can be paired with --float_bitwidth to indicate the bitwidth for
FP (by default 32).
If this option is enabled, then input list must not be provided and
--ignore_quantization_overrides must not be provided.
The external quantization encodings (encoding file/FakeQuant encodings)
might be missing quantization parameters for some interim tensors.
First it will try to fill the gaps by propagating across math-invariant
functions. If the quantization params are still missing,
then it will apply fallback to nodes to floating point.
Use this option to enable new optimization algorithms. Usage is:
--apply_algorithms <algo_name1> ... The available optimization algorithms
are: "cle" - Cross layer equalization includes a number of methods for
equalizing weights and biases across layers in order to rectify imbalances
that cause quantization errors.
Use the --bias_bitwidth option to select the bitwidth to use when quantizing
the biases, either 8 (default) or 32.
Use the --act_bitwidth option to select the bitwidth to use when quantizing
the activations, either 8 (default) or 16.
Use the --weights_bitwidth option to select the bitwidth to use when
quantizing the weights, either 2, 4, 8 (default) or 16.
Use the --float_bitwidth option to select the bitwidth to use for float
tensors,either 32 (default) or 16.
Use the --float_bias_bitwidth option to select the bitwidth to use when
biases are in float, either 32 or 16 (default '0' if not provided).
Use only quantizer generated encodings, ignoring any user or model provided
encodings.
Note: Cannot use --ignore_quantization_overrides with
--quantization_overrides (argument of Qairt Converter)
Use this option to enable per-channel quantization for convolution-based op
weights.
Note: This will only be used if built-in model Quantization-Aware Trained
(QAT) encodings are not present for a given weight.
Use this option to enable rowwise quantization of Matmul and FullyConnected
ops.
Use this option to enable rowwise quantization of bias for FullyConnected
ops, when weights are per-row quantized.
e.g.
of the graph.
Boolean flag to indicate how to read input files.
If not provided, reads inputs as floats and quantizes if necessary based on
quantization parameters in the model. (default)
If provided, reads inputs assuming the data type to be native to the model.
For ex., uint8_t.
Boolean flag to indicate the data type of the output files
If not provided, outputs the file as floats. (default)
If provided, outputs the file that is native to the model. For ex., uint8_t.
Specifies the number of steps to use for computing quantization encodings
such that scale = (max - min) / number of quantization steps.
The option should be passed as a space separated pair of hexadecimal string
minimum and maximum valuesi.e. --restrict_quantization_steps "MIN MAX".
Please note that this is a hexadecimal string literal and not a signed
integer, to supply a negative value an explicit minus sign is required.
E.g.--restrict_quantization_steps "-0x80 0x7F" indicates an example 8 bit
range,
--restrict_quantization_steps "-0x8000 0x7F7F" indicates an example 16
bit range.
This argument is required for 16-bit Matmul operations.
Use this option to keep the weights quantized even when the output of the op
is in floating point. Bias will be converted to floating point as per the
output of the op. Required to enable wFxp_actFP configurations according to
the provided bitwidth for weights and activations
Note: These modes are not supported by all runtimes. Please check
corresponding Backend OpDef supplement if these are supported
Use --adjust_bias_encoding option to modify bias encoding and weight
encoding to ensure that the bias value is in the range of the bias encoding.
This option is only applicable for per-channel quantized weights.
NOTE: This may result in clipping of the weight values
Specify which quantization calibration method to use for activations
supported values: min-max (default), sqnr, entropy, mse, percentile
This option can be paired with --act_quantizer_schema to override the
quantization
schema to use for activations otherwise default schema(asymmetric) will be
used
Specify which quantization calibration method to use for parameters
This option can be paired with --param_quantizer_schema to override the
quantization
schema to use for parameters otherwise default schema(asymmetric) will be
used
Specify which quantization schema to use for activations
supported values: asymmetric (default), symmetric, unsignedsymmetric
Specify which quantization schema to use for parameters
Specify the percentile value to be used with Percentile calibration method
The specified float value must lie within 90 and 100, default: 99.99
Use AIMET for Quantization instead of QNN IR quantizer
--op_package_lib OP_PACKAGE_LIB, -opl OP_PACKAGE_LIB
Use this argument to pass an op package library for quantization. Must be in
the form <op_package_lib_path:interfaceProviderName> and be separated by a
comma for multiple package libs
--dump_encoding_json Use this argument to dump encoding of all the tensors in a json file
--config CONFIG_FILE, -c CONFIG_FILE
Use this argument to pass the path of the config YAML file with quantizer
options
Use this argument to export a DLC which strips out data not needed for graph
composition
--debug [DEBUG] Run the quantizer in debug mode.
Backend Options:
option.
qnn-context-binary-generator tool is used to generate Context-Binary format model files for inference with specific backends
usage: qnn-context-binary-generator --model QNN_MODEL.so --backend QNN_BACKEND.so
--binary_file BINARY_FILE_NAME
[--model_prefix MODEL_PREFIX]
[--output_dir OUTPUT_DIRECTORY]
[--op_packages ONE_OR_MORE_OP_PACKAGES]
[--config_file CONFIG_FILE.json]
[--profiling_level PROFILING_LEVEL]
[--verbose] [--version] [--help]
REQUIRED ARGUMENTS:
--model <FILE> Path to the <qnn_model_name.so> file containing a QNN network.
To create a context binary with multiple graphs, use
comma-separated list of model.so files. The syntax is
<qnn_model_name_1.so>,<qnn_model_name_2.so>.
--backend <FILE> Path to a QNN backend .so library to create the context binary.
--binary_file <VAL> Name of the binary file to save the context binary to with
.bin file extension. If not provided, no backend binary is created.
If absolute path is provided, binary is saved in this path.
Else binary is saved in the same path as --output_dir option.
OPTIONAL ARGUMENTS:
--model_prefix Function prefix to use when loading <qnn_model_name.so> file
containing a QNN network. Default: QnnModel.
--output_dir <DIR> The directory to save output to. Defaults to ./output.
--op_packages <VAL> Provide a comma separated list of op packages
and interface providers to register. The syntax is:
op_package_path:interface_provider[,op_package_path:interface_provider...]
--profiling_level <VAL> Enable profiling. Valid Values:
1. basic: captures execution and init time.
2. detailed: in addition to basic, captures per Op timing
for execution.
3. backend: backend-specific profiling level specified
in the backend extension related JSON config file.
--profiling_option <VAL> Set profiling options:
1. optrace: Generates an optrace of the run.
--config_file <FILE> Path to a JSON config file. The config file currently
supports options related to backend extensions and
context priority. Please refer to SDK documentation
for more details.
--enable_intermediate_outputs Enable all intermediate nodes to be output along with
default outputs in the saved context.
Note that options --enable_intermediate_outputs and --set_output_tensors
are mutually exclusive. Only one of the options can be specified at a time.
--set_output_tensors <VAL> Provide a comma-separated list of intermediate output tensor names, for which the outputs
will be written in addition to final graph output tensors.
The syntax is: graphName0:tensorName0,tensorName1;graphName1:tensorName0,tensorName1.
In case of a single graph, its name is not necessary and a list of comma separated tensor
names can be provided, e.g.: tensorName0,tensorName1.
The same format can be provided in a .txt file.
--backend_binary <VAL> Name of the binary file to save a backend-specific context binary to with
--log_level Specifies max logging level to be set. Valid settings:
"error", "warn", "info" and "verbose"
--dlc_path <VAL> Paths to a comma separated list of Deep Learning Containers (DLC) from which to load the models.
Necessitates libQnnModelDlc.so as the --model argument.
To compose multiple graphs in the context, use comma-separated list of DLC files.
The syntax is <qnn_model_name_1.dlc>,<qnn_model_name_2.dlc>
Default: None
--input_output_tensor_mem_type <VAL> Specifies mem type to be used for input and output tensors during graph creation.
Valid settings:"raw" and "memhandle"
--platform_options <VAL> Specifies values to pass as platform options. Multiple platform options can be provided
using the syntax: key0:value0;key1:value1;key2:value2
--version Print the QNN SDK version.
--help Show this help message.
qnn-net-run
qnn-net-run tool is used to perform inference on models converted to QAIRT format using specific backends
Command Line Options:
[ --help ] Displays this help message.
[ --version ] Displays version information.
[ --model=<val> ] Path to the model containing a QNN network.
--retrieve_context and --model are mutually exclusive.
To compose multiple graphs, use comma-separated list of model.so files.
The syntax is <qnn_model_name_1.so>,<qnn_model_name_2.so>
--backend=<val> Path to a QNN backend to execute the model.
[ --dlc_path=<val> ] Paths to a comma separated list of Deep Learning Containers (DLC) from which to load the models. Neccesitates QnnModelDlc.so
To compose multiple graphs, use comma-separated list of DLC files.
Default: None
[ --input_list=<val> ]
Path to a file listing the inputs for the network.
If there are multiple graphs in model.so, this has
to be comma-separated list of input list files.
When multiple graphs are present, to skip execution of a graph use
"__"(double underscore without quotes) as the file name in the
[ --output_dir=<val> ]
[ --op_packages=<val> ]
Provide a comma-separated list of op packages,
interface providers, and, optionally, targets to
register. Valid values for target are CPU and HTP.
The syntax is:
op_package_path:interface_provider:target[,op_package_path:interface_provider:target...]
[ --output_data_type=<val> ]
Please refer to flag --use_native_output_files as this option is deprecated
[ --input_data_type=<val> ]
Please refer to flag --use_native_input_files as this option is deprecated
[ --native_input_tensor_names=<val> ]
Provide a comma-separated list of input tensor names,
for which the input files would be read/parsed in native format
Note that options --use_native_input_files and --native_input_tensor_names
[ --profiling_level=<val> ]
per Op timing for execution.
3. client : captures only the performance metrics
measured by qnn-net-run
4. backend: backend-specific profiling level
specified in the backend extension
[ --profiling_option=<val> ]
[ --model_prefix=<val> ]
Function prefix to use when loading <qnn_model_name.so>.
Default: QnnModel
[ --retrieve_context=<val> ]
Path to cached binary from which to load a saved
context from and execute graphs. --retrieve_context and
--model are mutually exclusive. Only one of the options
[ --binary_updates=<val> ]
Path to yaml that contains paths to binary updates.
Updates are applied after initial graph execution on
a per graph basis.
[ --perf_profile=<val> ]
Specifies perf profile to set. Valid settings are
"low_balanced", "balanced", "default","high_performance",
"sustained_high_performance", "burst","low_power_saver",
"power_saver", "high_power_saver", "custom(for internal use only)",
"extreme_power_saver" and "system_settings".
[ --config_file=<val> ]
for more details.
[ --log_level=<val> ]
"error", "warn", "info" and "verbose".
[ --duration=<val> ] Specifies the duration of the graph execution in seconds.
Loops over the input_list until this amount of time has transpired.
[ --num_inferences=<val> ]
Specifies the number of inferences.
Loops over the input_list until the number of inferences has transpired.
[ --fps=<val> ] Specifies the frames per seconds for execution
[ --keep_num_outputs=<val> ]
Specifies the number of outputs to be saved.
Once the number of outputs saved reaches the limit, subsequent outputs are discarded
[ --batch_multiplier=<val> ]
Specifies the value with which the batch value in input and output tensors dimensions will be multiplied.
The modified input and output tensors will be used only during the execute graphs.
Composed graphs will still use the tensor dimensions from model.
[ --timeout=<val> ] Specifies the value of the timeout for execution of graph in micro seconds.
Please note using this option with a backend that does not support timeout signals results in an error
[ --retrieve_context_timeout=<val> ]
Specifies the value of the timeout for initialization of graph in micro seconds.
Please note using this option with a backend that does not support timeout signals results in an error.
Also note that this option can only be used when loading a saved context through--retrieve_context option.
[ --set_output_tensors=<val> ]
Note that options --debug and --set_output_tensors
Also note that this option can not be used when graph is retrieved from context binary,
since the graph is already finalized when retrieved from context binary.
The syntax is: graphName0:tensorName0,tensorName1;graphName1:tensorName0,tensorName1In case of a single graph, its name is not necessary and a list of comma separated tensor
[ --retrieve_context_list=<val> ]
Provide the path to yaml file which contains info regarding multiple contexts
[ --debug ] Specifies that output from all layers of the network will be saved
Note that options --debug and --set_output_tensors are mutually exclusive.
This option can not be used when loading saved context through --retrieve_context option.
[ --shared_buffer ] Specifies creation of shared buffers for graph I/O between the application
and the device/coprocessor associated with a backend directly.
[ --synchronous ] Specifies that graphs should be executed synchronously rather than asynchronously.
If a backend does not support asynchronous execution, this flag is unnecessary.
[ --use_native_input_files ]
Specifies that the input files will be parsed in the data
type native to the graph. If not specified, input files will
be parsed in floating point.
[ --use_native_output_files ]
Specifies that the output files will be generated in the data
type native to the graph. If not specified, output files will
be generated in floating point.
[ --use_mmap ] Specifies that the context binary that is being read should be loaded
using the Memory-mapped (MMAP) file I/O. Please note some platforms
may not support this due to OS limitations in which case an error
is thrown when this option is used. This option is currently not supported
for DLC offline prepare use case.
[ --validate_binary ]
Specifies that the context binary will be validated before creating a context.
This option can only be used with backends that support binary validation.
[ --max_input_cache_tensor_sets=<val> ]
Specifies the maximum number of input tensor sets that can be cached.
Use value "-1" to cache all the input tensors created.
Note that options --max_input_cache_tensor_sets and --max_input_cache_size_mb are mutually exclusive.
[ --max_input_cache_size_mb=<val> ]
Specifies the maximum cache size in mega bytes(MB).
[ --platform_options=<val> ]
Specifies values to pass as platform options. Multiple platform options can be provided using the syntax: key0:value0;key1:value1;key2:value2
[ --graph_profiling_start_delay=<val> ]
Specifies graph profiling start delay in seconds. Please Note thatthis option can only be used
in conjunction with graph-level profiling handles.
[ --graph_profiling_num_executions=<val> ]
Specifies the maximum number of QnnGraph_execute/QnnGraph_executeAsynccalls to be profiled.
Please Note that this option can only beused in conjunction with graph-level profiling handles.
[ --io_tensor_mem_handle_type=<val> ]
Specifies mem handle type to be used for Input and output tensors during graph execution.
Valid settings:"ion" and "dma_buf".
[ --device_options=<val> ]
Specifies values to pass as device options. Multiple device options can be provided using the syntax: key0:value0;key1:value1;key2:value2.
Currently supported options:
device_id:<n> - selects a particular hardware device by ID to execute on. This ID will be used during QnnDevice creation. A default device will be chosen by the backend if an ID is not provided. This value will override a device ID selected in a backend config file.
core_id:<n> - selects a particular core by ID to execute on the selected device. This ID will be used during QnnDevice creation. A default core will be chosen by the backend if an ID is not provided. This value will override a core ID selected in a backend config file.
qnn-context-binary-utility tool validates the metadata of Context-Binary model files and serializes them into JSON files. These JSON files can be used to inspect Context-Binary models, which aids in debugging.
--context_binary=<val>
Path to cached context binary from which the binary info
will be extracted and written to json.
[ --json_file=<val> ]
Provide path along with the file name <DIR>/<FILE_NAME> to serialize
context binary info into json.
The directory path must exist. File with the FILE_NAME will be created at DIR.
[ --unified_qairt_format ]
Specifies the format of the output JSON file to be in the SNPE, QNN
unified cache info format.
Complete Reference Documentation
For detailed and complete documentation of QAIRT Tools, please refer to:
Local Documentation
Online Documentation
