Audio Classification
gst-ai-audio-classification performs audio event classification on an audio stream, identifying sound types (e.g., speech, music, ambient noise).
Uses the YAMNet model, with the default configuration using CPU inference.
Steps​
1. Verify Model and Labels​
ls -l /etc/models/yamnet.tflite
ls -l /etc/labels/yamnet.json
2. View Configuration​
cat /etc/configs/config-audio-classification.json
Key fields:
FieldDefaultDescription
file-path/etc/media/video-mp3.mp4Input audio/video file (MP3 encoded)
model/etc/models/yamnet.tfliteModel file
labels/etc/labels/yamnet.jsonLabel file
threshold10Confidence threshold
codecmp3Audio encoding format
runtimecpuInference hardware
Default uses CPU inference. For DSP inference, change runtime to dsp and add ml-framework: "tflite".
3. Run​
gst-ai-audio-classification --config-file=/etc/configs/config-audio-classification.json
Press Ctrl + C to stop.
Expected Output​
Terminal output:
Running app with model: /etc/models/yamnet.tflite and labels: /etc/labels/yamnet.json
The display shows the test video with audio classification results overlaid.
Validation​
  • Terminal continuously outputs audio classification results
  • Display shows classification labels
How It Works​
YAMNet is an audio event classification model based on the AudioSet dataset, supporting 521 audio categories. Pipeline flow:
filesrc → qtdemux → (audio decode) → qtimlaudioconverter
qtimltflite (inference)
qtimlaclassification
(classification label overlay)
