Build from Source
The Demos (gst-ai-*) and Python Apps use precompiled GStreamer plugins from apt. If you need to modify plugin source code (e.g., customize postprocessing logic, add custom model support) or write your own C/C++ inference programs, you can compile directly on the device.
Hello-QIM: Minimal C/C++ Example​
Hello-QIM is a minimal runnable GStreamer application showing how to create a pipeline and capture camera frames in C++. Use it as a starting point for custom applications.
Download Source​
git clone https://github.com/quic/sample-apps-for-qualcomm-linux
cd sample-apps-for-qualcomm-linux/Hello-QIM
Prepare Source File​
cp main.cc gst-appsink.cc
Create Makefile​
CC = g++
CFLAGS = -Wall -g $(shell pkg-config --cflags gstreamer-1.0)
LDFLAGS = $(shell pkg-config --libs gstreamer-1.0)
all: gst-appsink
gst-appsink: gst-appsink.o
$(CC) -o $@ $^ $(LDFLAGS)
gst-appsink.o: gst-appsink.cc
$(CC) $(CFLAGS) -c $<
clean:
rm -f gst-appsink gst-appsink.o
Compile and Run​
make
./gst-appsink -w 1280 -h 720
Expected output:
Hello-QIM: Success creating pipeline and received camera frame.
If the device has no camera connected, pipeline creation still succeeds — it just won't receive frames.
Compiling QIM Plugins (Advanced)​
If you need to modify the GStreamer plugins themselves (not just call them), compile all plugins from source.
Install Build Dependencies​
sudo apt install -y \
qcom-adreno-dev \
libgstreamer1.0-qcom-sample-apps-utils-dev
Download and Compile​
cd ~
apt source gst-plugins-qti-oss
cd gst-plugins-qti-oss-*
mkdir build && cd build
cmake \
-DCMAKE_INSTALL_PREFIX=/usr \
-DCMAKE_INSTALL_LIBDIR=lib/aarch64-linux-gnu \
-DCMAKE_INSTALL_BINDIR=bin \
-DCMAKE_INSTALL_SYSCONFDIR=/etc \
-DGST_VERSION_REQUIRED=1.24.0 \
-DENABLE_GST_PLUGIN_BASE=ON \
-DENABLE_GST_ML_PLUGINS=ON \
-DENABLE_GST_VIDEOPROC_PLUGINS=ON \
-DENABLE_GST_SAMPLE_APPS=ON \
make -j$(nproc)
sudo make install
This produces approximately 34 plugin shared libraries (libgstqtimltflite.so, libgstqtimlvclassification.so, etc.).
Troubleshooting​
CMake cannot find GStreamer​
Check that GStreamer development packages are installed:
pkg-config --modversion gstreamer-1.0
If not found:
sudo apt install libgstreamer1.0-dev
