Metadata Parser
gst-ai-metadata-parser-example performs object detection and parses the detection metadata (coordinates, class, confidence) into structured output, suitable for integration with external analytics systems or logging.
Steps​
1. Verify Model​
ls -l /etc/models/yolox_quantized.tflite
2. View Configuration​
cat /etc/configs/config-metadata-parser.json
3. Run​
gst-ai-metadata-parser-example --config-file=/etc/configs/config-metadata-parser.json
Press Ctrl + C to stop.
Expected Output​
Running app with model: /etc/models/yolox_quantized.tflite and labels: /etc/labels/yolox.json
Using DSP delegate
The display shows the detection view while the terminal streams structured detection metadata (JSON format).
Validation​
  • YOLOX model (329 ops) running on DSP
  • Terminal outputs valid metadata structures
