Model Export
The IM SDK download script (download_artifacts.sh) provides only 10 base TFLite models. The following demos require custom-exported models:
DemoRequired ModelExport Method
Multi-Input Multi-OutputYOLOv5 (yolov5.tflite)Export from YOLOv5 source
Multistream Batch InferenceYOLOv8 batch=4 (yolov8_det.tflite)Qualcomm AI Hub
Object Detection (YOLOv8/YOLO-NAS)YOLOv8 / YOLO-NASQualcomm AI Hub
Method 1: Export from YOLOv5 Source (for Multi-Input Multi-Output)​
host$
git clone https://github.com/ultralytics/yolov5.git
cd yolov5
python -m pip install -r requirements.txt tensorflow-cpu
python export.py --weights yolov5m.pt --img 320 --include tflite --int8 --data data/coco128.yaml
Push the exported model to the device:
host$
scp yolov5m-int8.tflite radxa@<device-ip>:/etc/models/yolov5.tflite
# Create yolov5 label file (copy yolonas labels)
sudo cp /etc/labels/yolonas.labels /etc/labels/yolov5.labels
This method uses --img 320 to match the demo's input resolution. Do not use the default 640, or inference will fail due to input size mismatch.
Method 2: Qualcomm AI Hub Export for YOLOv8 (Object Detection, Multistream Batch)​
1. Register and Get API Token​
Qualcomm AI Hub → Settings → API Token.
2. Install qai-hub-models​
host$
python -m venv qaihm
source qaihm/bin/activate
pip install qai-hub-models
3. Export Standard Model (batch=1)​
host$
python -m qai_hub_models.models.yolov8_det.export \
--quantize w8a8 \
--target-runtime=tflite \
--device "Dragonwing IQ-9075 EVK"
4. Export Batch Model (batch=4, for Multistream Batch Inference)​
host$
--quantize w8a8 \
--device "Dragonwing IQ-9075 EVK" \
--batch-size 4
--batch-size 4 must match the number of streams in the demo. Q900 (QCS9075) supports up to 4 streams.
5. Push to Device​
host$
scp yolov8_det.tflite radxa@<device-ip>:/etc/models/
