Multi-Input Multi-Output Inference
gst-ai-multi-input-output-object-detection runs object detection on multiple input sources simultaneously, with independent inference per stream. It supports combinations of file, RTSP, and camera inputs, with output to display, file, or RTSP stream.
Maximum 6 concurrent input streams.
Steps​
1. Prepare Input Videos​
The default configuration uses 6 file inputs. Copy the test video:
for i in $(seq 1 6); do
sudo cp /etc/media/video.mp4 /etc/media/video${i}.mp4
done
2. Prepare YOLOv5 Model​
The default configuration references /etc/models/yolov5.tflite, which is not included in the download script. Export from YOLOv5 source.
On the host machine:
host$
git clone https://github.com/ultralytics/yolov5.git
cd yolov5
python -m pip install -r requirements.txt tensorflow-cpu
python export.py --weights yolov5m.pt --img 320 --include tflite --int8 --data data/coco128.yaml
--img 320 is required: this demo's input resolution is 320×320. Using the default 640 will cause inference failure due to size mismatch.
Push the model to the device and create the label file:
host$
scp yolov5m-int8.tflite radxa@<device-ip>:/etc/models/yolov5.tflite
sudo cp /etc/labels/yolonas.labels /etc/labels/yolov5.labels
Note: This demo does NOT support the YOLOX model (yolox_quantized.tflite). The YOLOX model included in the download script works with other demos (e.g., gst-ai-object-detection), but this specific demo requires YOLOv5.
3. Modify Configuration​
python3 -c "
import json
with open('/etc/configs/config-multi-input-output-object-detection.json') as f:
c = json.load(f)
c['model'] = '/etc/models/yolov5.tflite'
c['labels'] = '/etc/labels/yolov5.labels'
json.dump(c, open('/tmp/cfg_multi_in_out.json', 'w'), indent=2)
print('config written')
4. Run​
gst-ai-multi-input-output-object-detection --config-file=/tmp/cfg_multi_in_out.json
Press Ctrl + C to stop.
Expected Output​
TARGET Can support file source, RTSP source and camera source
Run app with model: ... and labels: ...
IN Options: camera: 0 (id: 0), file: 6, rtsp: 0
OUT Options: display: 1, file: (null), rtsp: 0
VERBOSE: Replacing 334 out of 334 node(s) with delegate (TfLiteQnnDelegate) node
Pipeline state changed from NULL to READY:
Pipeline state changed from READY to PAUSED:
Pipeline state changed from PAUSED to PLAYING:
The display shows 6 concurrent detection streams, each with independent bounding boxes.
Validation​
  • 334 ops all delegated to DSP
  • Display shows 6 concurrent detection streams with independent bounding boxes
Configuration Reference​
FieldDescriptionDefault
input-file-pathFile input paths (JSON array, max 6)["/etc/media/video1.mp4", ...]
input-rtsp-pathRTSP input URLs (JSON array, max 6)empty
num-cameraNumber of camera streams (0–2)0
camera-idCamera device ID0
modelObject detection model path/etc/models/yolov5.tflite
labelsLabel file path/etc/labels/yolov5.json
output-displayEnable display outputtrue
output-file-pathOutput file path (optional)empty
output-rtsp-pathRTSP output URL (optional)empty
Pipeline Flow​
filesrc × 6 → qtdemux → h264parse → v4l2h264dec → qtimlvconverter
qtimltflite (DSP inference)
qtimlvdetection (YOLO postprocess)
qtivcomposer
waylandsink
