Multistream Batch Inference
gst-ai-multistream-batch-inference performs batch AI inference (object detection or image segmentation) on multiple video streams simultaneously, batching streams for a single inference pass to improve throughput.
Q900 (QCS9075) supports up to 24 concurrent input streams (6 batches × batch-size 4).
Steps​
1. Export Batch Model​
Export YOLOv8 with --batch-size 4. See Model Export for the full command.
Push the model and labels to the device:
host$
scp yolov8_det.tflite radxa@<device-ip>:/etc/models/
2. Create Configuration​
python3 -c "
import json
with open('/etc/configs/config-multistream-batch-inference.json') as f:
base = json.load(f)
entry = base['pipeline-info'][0]
entry['model-path'] = '/etc/models/yolov8_det.tflite'
entry['labels-path'] = '/etc/labels/yolov8.json'
# Generate 6 batches × 4 streams = 24 streams (id max=5)
base['pipeline-info'] = []
for i in range(6):
e = json.loads(json.dumps(entry))
e['id'] = i
base['pipeline-info'].append(e)
with open('/tmp/cfg_batch.json', 'w') as f:
json.dump(base, f, indent=2)
print('24-stream config written')
3. Run​
gst-ai-multistream-batch-inference --config-file=/tmp/cfg_batch.json
Press Ctrl + C to stop.
Expected Output​
VERBOSE: Replacing 282 out of 282 node(s) with delegate (TfLiteQnnDelegate) node
Pipeline state changed from NULL to READY:
Pipeline state changed from READY to PAUSED:
Pipeline state changed from PAUSED to PLAYING:
The display shows 24 concurrent detection streams.
Validation​
  • All ops delegated to DSP
  • 24 streams display correct bounding boxes simultaneously
Configuration Reference​
FieldDescriptionDefault
output-typeOutput type: wayland / filesinkwayland
pipeline-info[].idBatch ID (0–5)0
pipeline-info[].input-typeInput source typefile
pipeline-info[].input-file-pathInput files (4 per batch)See config
pipeline-info[].mlframeworkInference frameworktflite
pipeline-info[].model-pathModel pathMust be replaced
pipeline-info[].labels-pathLabel pathMust be replaced
pipeline-info[].constantsLiteRT quantization constantsModel-specific
pipeline-info[].post-process-pluginPost-process plugin: qtimlvdetection / qtimlvsegmentationqtimlvdetection
Pipeline Flow​
filesrc × 4 → qtdemux → h264parse → v4l2h264dec → qtibatch (batch)
qtimlvconverter
qtimltflite (DSP batch inference)
qtimldemux (debatch)
qtivcomposer
waylandsink
