Object Detection
gst-ai-object-detection performs object detection on each frame of a video stream, drawing bounding boxes around detected objects with class labels and confidence scores.
Supports YOLOX, YOLOv8, and YOLO-NAS models.
Steps​
1. Verify Model and Labels​
ls -l /etc/models/yolox_quantized.tflite
ls -l /etc/labels/yolox.json
2. View Configuration​
cat /etc/configs/config_detection.json
Key fields:
FieldDefaultDescription
file-path/etc/media/video.mp4Input video path
ml-frameworktfliteInference framework
yolo-model-typeyoloxYOLO type: yolov5 / yolov8 / yolox / yolonas
model/etc/models/yolox_quantized.tfliteModel file
labels/etc/labels/yolox.jsonLabel file
threshold40Confidence threshold (1-100)
runtimedspInference hardware
3. Run​
gst-ai-object-detection --config-file=/etc/configs/config_detection.json
Press Ctrl + C to stop.
Expected Output​
Terminal output:
Running app with model: /etc/models/yolox_quantized.tflite and labels: /etc/labels/yolox.json
Using DSP Delegate
The display shows the test video with colored bounding boxes around detected objects, annotated with class names and confidence scores.
Validation​
  • Using DSP Delegate: Inference running on NPU
  • Replacing 329 out of 329 node(s): All 329 operators delegated to DSP
  • Display correctly shows bounding boxes and labels
Adjusting Detection Sensitivity​
If too few objects are detected (missed detections), lower the threshold:
# Change threshold to 20 in /etc/configs/config_detection.json
If there are too many false positives, increase the threshold (e.g., 60).
Switching YOLO Models​
Modify the model type and path in the config file:
"yolo-model-type": "yolov8",
"model": "/etc/models/yolov8_det_quantized.tflite",
"labels": "/etc/labels/yolov8.json"
YOLOv8 and YOLO-NAS models require separate export via Qualcomm AI Hub.
Pipeline Flow​
filesrc → qtdemux → h264parse → v4l2h264dec → qtimlvconverter
qtimltflite (DSP inference)
qtimlvdetection (YOLO post-process)
qtivcomposer
waylandsink
