Parallel AI Fusion
gst-ai-parallel-inference runs multiple AI models simultaneously on a single video stream, with all models inferring in parallel on the NPU and results fused into a single display.
The default configuration runs 4 models concurrently: object detection (YOLOX), classification (InceptionV3), pose detection (HRNet), and segmentation (DeepLabV3+), all executing in parallel on DSP.
Steps​
1. Verify Models​
ls -l /etc/models/{yolox_quantized,inception_v3_quantized,hrnet_pose_quantized,deeplabv3_plus_mobilenet_quantized}.tflite
2. View Configuration​
cat /etc/configs/config-parallel-inference.json
3. Run​
gst-ai-parallel-inference --config-file=/etc/configs/config-parallel-inference.json
Press Ctrl + C to stop.
Expected Output​
VERBOSE: Replacing 142 out of 142 node(s) with delegate (TfLiteQnnDelegate) node
VERBOSE: Replacing 518 out of 518 node(s) with delegate (TfLiteQnnDelegate) node
VERBOSE: Replacing 136 out of 136 node(s) with delegate (TfLiteQnnDelegate) node
The display simultaneously shows bounding boxes, classification labels, human skeletons, and segmentation masks — all four AI results overlaid on the same frame.
Validation​
  • 4 models (329 + 142 + 518 + 136 = 1,125 operators) running in parallel on DSP
  • Display shows all four inference results simultaneously
This demonstrates that the Q900 HTP V73 NPU supports concurrent multi-model processing.
