Pose Detection
gst-ai-pose-detection performs human pose detection on each frame of a video stream, drawing skeleton connections between body keypoints.
Uses the HRNet model.
Steps​
1. Verify Required Files​
ls -l /etc/models/hrnet_pose_quantized.tflite
ls -l /etc/labels/hrnet_pose.json
ls -l /etc/labels/hrnet_settings.json
hrnet_settings.json defines the connections between body joints. Missing this file causes Invalid pose settings path error.
2. View Configuration​
cat /etc/configs/config_pose.json
Key fields:
FieldDefaultDescription
file-path/etc/media/video.mp4Input video path
ml-frameworktfliteInference framework
model/etc/models/hrnet_pose_quantized.tfliteModel file
labels/etc/labels/hrnet_pose.jsonLabel file
pose-settings-path/etc/labels/hrnet_settings.jsonJoint connection config
runtimedspInference hardware
3. Run​
gst-ai-pose-detection --config-file=/etc/configs/config_pose.json
Press Ctrl + C to stop.
Expected Output​
Terminal output:
Running app with model: /etc/models/hrnet_pose_quantized.tflite and labels: /etc/labels/hrnet_pose.json and settings /etc/labels/hrnet_settings.json
Using DSP Delegate
VERBOSE: Replacing 518 out of 518 node(s) with delegate (TfLiteQnnDelegate) node
The display shows the test video with skeleton connections drawn between body keypoints.
Validation​
  • Using DSP Delegate: Inference running on NPU
  • Replacing 518 out of 518 node(s): All 518 operators delegated to DSP
  • Display correctly shows human skeleton overlay
Troubleshooting​
Invalid pose settings path​
Verify hrnet_settings.json exists under /etc/labels/:
If missing, re-run the download script:
sudo ./download_artifacts.sh -v GA1.6-rel -c QCS9075
