Python GStreamer Apps
The Demos (gst-ai-*) are precompiled CLI tools controlled via JSON config files. If you need to insert custom processing logic into the pipeline (e.g., OpenCV preprocessing, custom postprocessing), use the Python GStreamer bindings to build pipelines directly.
QIM SDK Python examples are installed via the gstreamer1.0-qcom-python-examples package. Scripts are located in /usr/bin/ and use the same underlying GStreamer plugins (qtimltflite, qtimlvdetection, qtivcomposer, etc.) as the gst-ai-* demos, but use argparse command-line arguments instead of config JSON.
Python dependencies (python3-gst-1.0, python3-numpy, python3-opencv) are installed automatically.
Representative Examples​
18 runnable scripts are installed. Here are a few representative ones:
ScriptDescriptionExample
gst-ai-object-detection.pyObject detectionpython3 /usr/bin/gst-ai-object-detection.py -s /etc/media/video.mp4 -f 2 -ml yolov5 -m /etc/models/yolov5m-int8.tflite -l /etc/labels/yolov5.json --use_dsp
gst-parallel-inference.pyMulti-model parallel inferenceRun detection + classification + segmentation simultaneously
gst-daisychain-detection-pose.pyCascaded detection + pose--file /etc/media/video.mp4 --tflite-yolo-model ... --tflite-pose-model ...
gst-concurrent-videoplay-composition.pyVideo wall--infile /etc/media/video.mp4 -c 4 (4 concurrent streams)
Use --help on any script to see its full parameter list.
Basic Structure​
Python GStreamer apps use PyGObject bindings. Minimal example:
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GLib
Gst.init(None)
# Create pipeline
pipeline = Gst.parse_launch(
"filesrc location=/etc/media/video.mp4 ! "
"qtdemux ! h264parse ! v4l2h264dec ! waylandsink"
# Start
pipeline.set_state(Gst.State.PLAYING)
# Main loop
loop = GLib.MainLoop()
loop.run()
Get Source Code​
Full source code for all Python examples is on GitHub:
git clone https://github.com/quic/sample-apps-for-qualcomm-linux
Reference​
  • Demos — Precompiled CLI, controlled via config JSON
  • Build from Source — C/C++ approach for deep plugin customization
