NPU Quick Verification
This document provides an out-of-the-box resnet50 object recognition model inference example. This example performs hardware-accelerated inference using Qualcomm® Hexagon™ Processor (NPU) on Radxa Dragon Ubuntu system.
Before performing NPU Quick Verification, please refer to Enable NPU on Board to make sure the NPU is enabled.
Download Example​
pip3 install modelscope
modelscope download --model radxa/resnet50_qairt --local ./resnet50_qairt
Run Example​
Please import environment variables according to SoC
export PRODUCT_SOC=9075
Execute model inference
cd resnet50_qairt/${PRODUCT_SOC}
chmod +x qnn-net-run
./qnn-net-run --backend ./libQnnHtp.so --retrieve_context ./resnet50_aimet_quantized_${PRODUCT_SOC}.bin --input_list ./test_list.txt --output_dir output_bin
Verify Example​
You can use python script for result verification
cd ../scripts
python3 show_resnet50_classifications.py --input_list ../${PRODUCT_SOC}/test_list.txt -o ../${PRODUCT_SOC}/output_bin/ --labels_file ../data/imagenet_classes.txt
$ python3 show_resnet50_classifications.py --input_list ../${PRODUCT_SOC}/test_list.txt -o ../${PRODUCT_SOC}/output_bin/ --labels_file ../data/imagenet_classes.txt
Classification results
../data/test/crop/ILSVRC2012_val_00003441.raw 21.476509 402 acoustic guitar
../data/test/crop/ILSVRC2012_val_00008465.raw 22.651005 927 trifle
../data/test/crop/ILSVRC2012_val_00010218.raw 12.248322 281 tabby
../data/test/crop/ILSVRC2012_val_00044076.raw 18.456375 376 proboscis monkey
By comparing the printed results with the test image content, you can confirm that the output results of the resnet50 model ported to Qualcomm® NPU are correct.
resnet50 input images
