AMR Simple Motion Control
Keyboard-controlled motion of a simulated AMR (Autonomous Mobile Robot) in Gazebo. The control node publishes Twist commands to /qrb_robot_base/cmd_vel, forwarded through ros_gz_bridge to the Gazebo differential-drive system, with odom feedback confirming actual robot motion.
Data Flow​
simple_motion → /qrb_robot_base/cmd_vel → ros_gz_bridge → Gazebo → /qrb_robot_base/odom
Build from Source​
Step 1: Install Dependencies​
sudo apt install -y \
ros-jazzy-ros-gz \
ros-jazzy-gz-ros2-control \
ros-jazzy-ros2-controllers
Step 2: Clone and Build​
cd qrb_ros_simulation
colcon build --cmake-args -DBUILD_TESTING=OFF
Run (GUI Mode)​
Terminal 1 — Start Gazebo simulation from a desktop terminal:
source ~/qrb_ros_simulation/install/setup.bash
ros2 launch qrb_ros_sim_gazebo gazebo_robot_base.launch.py \
namespace:=qrb_robot_base enable_laser:=false enable_imu:=false
AMR Gazebo simulation
Once the Gazebo window opens, click the play button at the bottom-left to start the simulation.
Terminal 2 — Start the controller:
ros2 run simulation_sample_amr_simple_motion simple_motion
Keyboard Controls​
KeyCommandTwist Value
iForwardlinear.x = 0.5
,Backwardlinear.x = -0.5
jCCW turnangular.z = 0.5
lCW turnangular.z = -0.5
kStoplinear.x = 0.0
qQuit
Verification​
After pressing i to send a forward command, the AMR in the Gazebo window should move visibly. Confirm via the odom topic:
ros2 topic echo /qrb_robot_base/odom --field pose.pose.position.x
Expected: position.x grows from approximately 0.
Headless Mode​
To run without a display, use headless mode for the Gazebo server and ros_gz_bridge only:
namespace:=qrb_robot_base enable_laser:=false enable_imu:=false \
headless:=true
Extension: Navigation and SLAM​
Enable LiDAR and IMU for a full sensory setup:
namespace:=qrb_robot_base \
enable_laser:=true \
enable_imu:=true \
enable_odom:=true \
enable_odom_tf:=true
Available interfaces:
TopicType
/qrb_robot_base/cmd_velTwist
/qrb_robot_base/odomOdometry
/qrb_robot_base/joint_statesJointState
/qrb_robot_base/tfTFMessage
/qrb_robot_base/scanLaserScan (requires enable_laser:=true)
/qrb_robot_base/imuImu (requires enable_imu:=true)
This foundation supports Nav2 navigation, 2D SLAM, obstacle avoidance, path planning, and more (additional packages required).
Note: The cross-machine topology described in the official document (x86 host running Gazebo + Q900 controlling via DDS) has not been verified. If using this setup, ensure ROS_DOMAIN_ID matches and the network supports multicast between the host and Q900.
