ROS Component Performance Benchmark
Evaluate the performance of ROS components on Q900, supporting standard ROS message types and QRB Transport DMA-BUF zero-copy types.
Out-of-the-Box​
Step 1: Install​
sudo apt install -y ros-jazzy-qrb-ros-benchmark
Step 2: Create Benchmark Template​
The following template tests QRB Transport Image type (DMA-BUF zero-copy) with corrected topic remappings:
cat > image_benchmark.launch.py << 'EOF'
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
from ros2_benchmark import ROS2BenchmarkConfig, ROS2BenchmarkTest
def launch_setup(container_prefix, container_sigterm_timeout):
data_loader_node = ComposableNode(
name='DataLoaderNode',
namespace=TestQrbNode.generate_namespace(),
package='ros2_benchmark',
plugin='ros2_benchmark::DataLoaderNode',
remappings=[('data_loader_image', '/data_loader_image')],
playback_node = ComposableNode(
name='QrbPlaybackNode',
package='qrb_ros_benchmark',
plugin='qrb_ros::benchmark::QrbPlaybackNode',
parameters=[{
'data_formats': ['qrb_ros/transport/type/Image'],
remappings=[
('buffer/input0', '/data_loader_image'),
('input0', '/playback_image'),
monitor_node = ComposableNode(
name='QrbMonitorNode',
plugin='qrb_ros::benchmark::QrbMonitorNode',
parameters=[{
'monitor_data_format': 'qrb_ros/transport/type/Image',
remappings=[('output', '/playback_image')],
container = ComposableNodeContainer(
name='container',
package='rclcpp_components',
executable='component_container_mt',
prefix=container_prefix,
sigterm_timeout=container_sigterm_timeout,
composable_node_descriptions=[
data_loader_node,
playback_node,
monitor_node,
output='screen',
return [container]
def generate_test_description():
return TestQrbNode.generate_test_description_with_nsys(launch_setup)
class TestQrbNode(ROS2BenchmarkTest):
config = ROS2BenchmarkConfig(
benchmark_name='QRB Image Transport Benchmark',
input_data_path='/path/to/rosbag',
publisher_upper_frequency=100.0,
publisher_lower_frequency=100.0,
playback_message_buffer_size=10,
test_iterations=3,
def test_benchmark(self):
self.run_benchmark()
EOF
Key parameters:
  • input_data_path: path to the test rosbag
  • publisher_upper_frequency / publisher_lower_frequency: search window bounds
  • test_iterations: number of iterations; use at least 3 to avoid a statistical boundary bug
Step 3: Generate Test Rosbag​
python3 -c "
from ros2_benchmark import RosbagGenerator
RosbagGenerator.generate_fixed_messages(
output_path='image_bag',
topic_name='/data_loader_image',
msg_type='sensor_msgs/msg/Image',
resolution=(320, 240),
encoding='rgb8',
message_count=10,
Step 4: Run Benchmark​
launch_test image_benchmark.launch.py input_data_path:=image_bag
Build from Source​
Step 1: Clone Repositories​
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_benchmark.git
git clone https://github.com/qualcomm-qrb-ros/ros2_benchmark.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_transport.git
git clone https://github.com/qualcomm-qrb-ros/lib_mem_dmabuf.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_imu.git
git clone https://github.com/qualcomm-qrb-ros/dmabuf_transport.git
Step 2: Build​
cd ~/qrb_ros_ws
colcon build
Step 3: Run​
source ~/qrb_ros_ws/install/setup.bash
Expected Output​
Predicted sustainable frequency:  99.375 Hz
Actual average receive rate: 99.867 FPS
Frames sent: 198
Dropped frames: 0
Average frame jitter: 0.312 ms
Average CPU: 2.074%
Ran 1 test
OK
APT version 1.0.0 may segfault during component unload after the test completes (benchmark data is unaffected). The source-built version has resolved this.
