Color Space Conversion
Convert between NV12 and RGB888 color space formats. Qualcomm smart devices use NV12 as the default format, while RGB888 is the common image processing format. This sample supports DMA-BUF input/output and QRB ROS Transport zero-copy transfer, with both GPU (OpenGL ES) and CPU (OpenCV) backends.
The verification below uses the CPU/OpenCV backend, which requires no display or GPU.
Build from Source​
Step 1: Clone the Repository​
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_color_space_convert.git
Step 2: Build (CPU/OpenCV Backend)​
cd qrb_ros_color_space_convert
colcon build --packages-up-to qrb_ros_colorspace_convert \
--cmake-args -DUSE_OPENCV_BACKEND=ON -DBUILD_TESTING=OFF
The GPU backend uses OpenGL ES and requires qcom-adreno-dev, weston, and a connected display. Use -DUSE_OPENCV_BACKEND=OFF instead.
Run​
A custom ROS node is needed to publish test images to /image_raw. The example below uses a Python test script.
Terminal 1 — Start the conversion node:
source install/setup.bash
ros2 launch qrb_ros_colorspace_convert colorspace_convert.launch.py \
conversion_type:=nv12_to_rgb8 latency_fps_test:=False
Terminal 2 — Run the test script:
python3 test/colorspace_ros_test.py nv12_to_rgb8 \
--output artifacts/data/nv12_to_rgb8.raw
The test script publishes a 64×48 known pattern to /image_raw, subscribes to /image, and compares the result byte-for-byte against an independent OpenCV reference.
For the reverse direction (RGB8 → NV12), change conversion_type and the script argument to rgb8_to_nv12.
Expected Output​
mode=nv12_to_rgb8
input=nv12
output=rgb8
width=64
height=48
max_error=0
mean_error=0.000000
result=PASS
max_error=0 indicates the effective pixel data is byte-identical to the reference.
