YOLOv8 Object Detection
Run YOLOv8-N object detection with the official Ultralytics bus.jpg. The sample runs inference on the DSP through the QNN HTP backend and publishes both structured detections and an image with rendered bounding boxes.
This page covers local image input only. QRB, Orbbec, and USB camera input were not verified.
Source Build Required
The qrb_ros_nn_inference 1.1.1 and qrb_ros_cv_tensor_common_process 0.0.0 packages currently available on Q900 cannot directly run a version 3 context binary exported by current QAI Hub. Build the interfaces, inference, tensor processing, and sample sources in one workspace so all components use the same TensorList ABI.
Pipeline​
-> NV12 image publisher -> /image_raw
-> resize, normalization, and NHWC float32 conversion
-> QNN YOLOv8 inference
-> /yolo_detect_tensor_output
-> NMS and COCO label mapping
-> /yolo_detect_result
-> bounding-box overlay
-> /yolo_detect_overlay
ROS 2 Topics​
TopicTypePublisher
/image_rawsensor_msgs/msg/ImageLocal NV12 image publisher
/qrb_inference_input_tensorqrb_ros_tensor_list_msgs/msg/TensorListyolo_preprocess_node
/yolo_detect_tensor_outputqrb_ros_tensor_list_msgs/msg/TensorListnn_inference_node
/yolo_detect_resultvision_msgs/msg/Detection2DArrayyolo_detection_postprocess_node
/yolo_detect_overlaysensor_msgs/msg/Imageyolo_detection_overlay_node
  • QIR SDK installed
  • GitHub and Ultralytics access from the Q900
  • At least 1 GB free on the Q900
Export the Model on the Host​
Generate the QCS9075 context binary through QAI Hub.
Step 1: Install QAI Hub Models​
host$
python3 -m venv ~/venv_qaihub
source ~/venv_qaihub/bin/activate
pip install qai-hub-models
Step 2: Configure QAI Hub​
Obtain an API token from the account settings page in Qualcomm AI Hub:
host$
qai-hub configure --api_token <your-api-token>
Step 3: Export the QCS9075 Model​
Use Dragonwing IQ-9075 EVK as the target device:
host$
python3 -m qai_hub_models.models.yolov8_det.export \
--target-runtime qnn_context_binary \
--device "Dragonwing IQ-9075 EVK" \
--device-os 1.7 \
--skip-profiling \
--skip-inferencing \
--output-dir ~/qai_hub_models/yolov8_det_qcs9075
This command downloads the YOLOv8-N weights, compiles the model on QAI Hub, and downloads yolov8_det.bin.
Step 4: Transfer the Model and Labels​
Locate the exported model and the coco8.yaml supplied by Ultralytics:
host$
MODEL_PATH=$(find ~/qai_hub_models/yolov8_det_qcs9075 \
-type f -name yolov8_det.bin -print -quit)
LABEL_PATH=$(python3 -c \
'import pathlib, ultralytics; print(pathlib.Path(ultralytics.__file__).parent / "cfg/datasets/coco8.yaml")')
test -n "$MODEL_PATH" && test -f "$LABEL_PATH"
scp "$MODEL_PATH" <device-user>@<device-ip>:/tmp/yolov8_det_qcs9075.bin
scp "$LABEL_PATH" <device-user>@<device-ip>:/tmp/coco8.yaml
Install both files on the Q900:
sudo install -d -m 0755 /opt/model
sudo install -m 0644 /tmp/yolov8_det_qcs9075.bin \
/opt/model/yolov8_det_qcs9075.bin
sudo install -m 0644 /tmp/coco8.yaml /opt/coco8.yaml
Build from Source​
Step 1: Install Dependencies​
sudo apt install -y \
ros-dev-tools \
ros-jazzy-sample-object-detection \
ros-jazzy-qrb-ros-cv-tensor-common-process \
ros-jazzy-image-publisher
Step 2: Clone the Source​
Create a workspace and place all related repositories under the same src directory:
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_interfaces.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_nn_inference.git
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_tensor_process.git
Step 3: Build Inference and Sample Packages​
cd ~/qrb_ros_ws
colcon build \
--packages-up-to sample_object_detection \
--allow-overriding qrb_ros_tensor_list_msgs
Step 4: Build the Image Preprocessor​
sample_object_detection does not declare a source dependency on the image preprocessor, so build it explicitly:
cd ~/qrb_ros_ws
source install/setup.bash
colcon build \
--packages-select qrb_ros_cv_tensor_common_process \
Prepare the Test Image​
Download the official Ultralytics test image:
mkdir -p ~/qrb_ros_ws/input
wget https://ultralytics.com/images/bus.jpg \
-O ~/qrb_ros_ws/input/bus.jpg
echo "c02019c4979c191eb739ddd944445ef408dad5679acab6fd520ef9d434bfbc63 $HOME/qrb_ros_ws/input/bus.jpg" | \
sha256sum --check
Create the Static Image Publisher​
Create ~/qrb_ros_ws/nv12_image_publisher.py to resize the JPEG to 640 x 640 and convert it to NV12:
import sys
import cv2
import numpy as np
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
class Nv12ImagePublisher(Node):
def __init__(self, image_path):
super().__init__("nv12_image_publisher")
image = cv2.imread(image_path, cv2.IMREAD_COLOR)
if image is None:
raise RuntimeError(f"Failed to load image: {image_path}")
image = cv2.resize(image, (640, 640), interpolation=cv2.INTER_LINEAR)
height, width = image.shape[:2]
i420 = cv2.cvtColor(image, cv2.COLOR_BGR2YUV_I420).reshape(-1)
y_size = width * height
chroma_size = y_size // 4
y = i420[:y_size]
u = i420[y_size : y_size + chroma_size]
v = i420[y_size + chroma_size : y_size + 2 * chroma_size]
uv = np.empty(y_size // 2, dtype=np.uint8)
uv[0::2] = u
uv[1::2] = v
self.message = Image()
self.message.header.frame_id = "camera"
self.message.height = height
self.message.width = width
self.message.encoding = "nv12"
self.message.is_bigendian = False
self.message.step = width
self.message.data = np.concatenate((y, uv)).tobytes()
self.publisher = self.create_publisher(Image, "/image_raw", 10)
self.timer = self.create_timer(0.1, self.publish_image)
self.get_logger().info(
f"Publishing {image_path} as nv12 ({width}x{height})"
def publish_image(self):
self.message.header.stamp = self.get_clock().now().to_msg()
self.publisher.publish(self.message)
def main():
if len(sys.argv) != 2:
raise SystemExit("usage: nv12_image_publisher.py <image-path>")
rclpy.init()
node = Nv12ImagePublisher(sys.argv[1])
try:
rclpy.spin(node)
except KeyboardInterrupt:
pass
finally:
node.destroy_node()
if rclpy.ok():
rclpy.shutdown()
if __name__ == "__main__":
main()
Create the Image Input Launch File​
Create ~/qrb_ros_ws/launch_with_image_publisher.py:
from launch import LaunchDescription
from launch.actions import DeclareLaunchArgument, ExecuteProcess
from launch.substitutions import LaunchConfiguration
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
declared_args = [
DeclareLaunchArgument("image_path"),
DeclareLaunchArgument("publisher_script"),
DeclareLaunchArgument("model"),
DeclareLaunchArgument("label_file"),
DeclareLaunchArgument("score_thres", default_value="0.7"),
DeclareLaunchArgument("iou_thres", default_value="0.5"),
image_publisher = ExecuteProcess(
cmd=[
"python3",
LaunchConfiguration("publisher_script"),
LaunchConfiguration("image_path"),
output="screen",
preprocess = ComposableNode(
package="qrb_ros_cv_tensor_common_process",
plugin="qrb_ros::cv_tensor_common_process::CvTensorCommonProcessNode",
name="yolo_preprocess_node",
parameters=[
{"target_res": "640x640"},
{"normalize": True},
{"tensor_fmt": "nhwc"},
{"data_type": "float32"},
remappings=[
("input_image", "/image_raw"),
("encoded_image", "qrb_inference_input_tensor"),
inference = ComposableNode(
package="qrb_ros_nn_inference",
plugin="qrb_ros::nn_inference::QrbRosInferenceNode",
name="nn_inference_node",
parameters=[
"backend_option": "/usr/lib/libQnnHtp.so",
"model_path": LaunchConfiguration("model"),
remappings=[
("qrb_inference_output_tensor", "yolo_detect_tensor_output"),
postprocess = ComposableNode(
package="qrb_ros_yolo_process",
plugin="qrb_ros::yolo_process::YoloDetPostProcessNode",
name="yolo_detection_postprocess_node",
parameters=[
{"label_file": LaunchConfiguration("label_file")},
{"score_thres": LaunchConfiguration("score_thres")},
{"iou_thres": LaunchConfiguration("iou_thres")},
overlay = ComposableNode(
plugin="qrb_ros::yolo_process::YoloDetOverlayNode",
name="yolo_detection_overlay_node",
parameters=[{"target_res": "640x640"}],
container = ComposableNodeContainer(
name="yolo_node_container",
namespace="",
package="rclcpp_components",
executable="component_container",
composable_node_descriptions=[overlay, postprocess, inference, preprocess],
output="screen",
return LaunchDescription(declared_args + [image_publisher, container])
Run​
cd ~/qrb_ros_ws
export ROS_DOMAIN_ID=123
ros2 launch ~/qrb_ros_ws/launch_with_image_publisher.py \
publisher_script:="$HOME/qrb_ros_ws/nv12_image_publisher.py" \
image_path:="$HOME/qrb_ros_ws/input/bus.jpg" \
model:=/opt/model/yolov8_det_qcs9075.bin \
label_file:=/opt/coco8.yaml
Expected Output​
The model initializes and repeatedly performs inference:
Context binary info (V3/FCB)
Inference init successfully!
Got model input data, start executing inference...
Publish the inference result...
The /yolo_detect_overlay captured on the device is shown below:
YOLOv8 object detection result
Validation​
Check the detection and overlay topics from another terminal:
cd ~/qrb_ros_ws
ros2 topic info /yolo_detect_result -v
ros2 topic info /yolo_detect_overlay -v
ros2 topic echo /yolo_detect_result --once
At the default score threshold of 0.7, the test image should contain four detections:
person  0.8867
person 0.8794
bus 0.8755
person 0.8647
/yolo_detect_overlay should be a 640 x 640 bgr8 image. For graphical inspection, start rqt in a ROS 2 Jazzy desktop environment using the same ROS_DOMAIN_ID as the Q900. Select Plugins > Visualization > Image View, then select /yolo_detect_overlay.
Stop​
Press Ctrl + C in the terminal running the sample.
Limitations​
  • Only local image input was verified. QRB, Orbbec, and USB cameras were not tested.
  • The input image is resized to 640 x 640; bounding-box coordinates refer to the resized image.
  • Cross-device rqt display was not verified. Only local Q900 inference, detection messages, and overlay publication were validated.
  • The related repositories must be built from source. Mixing Debian and source versions of TensorList causes an ABI incompatibility.
