Simulated Remote Assistant
Simulate an AMR remote assistant task in a Gazebo office scene. The robot maps and relocalizes with Cartographer, navigates to a specified room with Nav2, and uses YOLOv8 to detect target objects, completing the end-to-end "go to office to check person" workflow.
Office scene overview
Build from Source​
Step 1: Clone Repositories​
# Simulation environment (skip if already built)
# Remote assistant sample
git clone -b jazzy-rel https://github.com/qualcomm-qrb-ros/qrb_ros_samples.git
Step 2: Build​
# Build simulation environment
cd qrb_ros_simulation
colcon build
# Build remote assistant sample
cd ../qrb_ros_samples/robotics/simulation_remote_assistant
source install/setup.bash
colcon build
Model Preparation​
Export a YOLOv8 float TFLite model through QAI Hub.
Step 1: Install QAI Hub Models​
host$
python -m venv ~/venv_qaihub
source ~/venv_qaihub/bin/activate
pip install qai-hub-models
Step 2: Configure QAI Hub​
Obtain an API token from the account settings page in Qualcomm AI Hub:
host$
qai-hub configure --api_token <your-api-token>
Step 3: Export the TFLite Model​
host$
python -m qai_hub_models.models.yolov8_det.export \
--precision=float \
--target-runtime=tflite \
--device "Dragonwing IQ-9075 EVK"
Step 4: Transfer the Model to the Device​
host$
scp yolov8_det.tflite <device-user>@<device-ip>:<your_model_path>/yolov8_det.tflite
Tensor specification:
TensorTypeShape
Inputfloat32[1, 640, 640, 3]
boxesfloat32[1, 8400, 4]
scoresfloat32[1, 8400]
class_idxuint8[1, 8400]
Run​
Use the same environment in all terminals:
export ROS_DOMAIN_ID=78
export ROS_LOCALHOST_ONLY=1
source qrb_ros_simulation/install/setup.bash
source qrb_ros_samples/robotics/simulation_remote_assistant/install/setup.bash
Terminal 1: Start Gazebo Office Scene​
Run from the desktop terminal:
ros2 launch qrb_ros_sim_gazebo gazebo_robot_base_mini.launch.py \
world_model:=office \
initial_x:=1.0 \
initial_y:=6.0 \
enable_depth_camera:=false
Simulation initial paused state
Gazebo starts in a paused state. Click the play button at the bottom-left to start the simulation clock before continuing.
Terminal 2: Mapping, Relocalization, and Navigation​
ros2 launch simulation_remote_assistant map_nav_setup.launch.py
This launch file orchestrates: Cartographer mapping → trajectory completion → pbstream save → relocalization → Nav2 bringup. The /navigate_to_pose action becomes available when complete.
Terminal 3: YOLO Object Detection​
ros2 launch simulation_remote_assistant yolo_detectcion.launch.py \
model:=<your_model_path>/yolov8_det.tflite \
label_file:=<your_path>/coco80_labels.yaml \
score_thres:=0.3
coco80_labels.yaml is a COCO 80-class label file not included in the repository. Create it:
cat > coco80_labels.yaml << 'EOF'
names:
0: person
1: bicycle
2: car
3: motorcycle
4: airplane
5: bus
6: train
7: truck
8: boat
9: traffic light
10: fire hydrant
11: stop sign
12: parking meter
13: bench
14: bird
15: cat
16: dog
17: horse
18: sheep
19: cow
20: elephant
21: bear
22: zebra
23: giraffe
24: backpack
25: umbrella
26: handbag
27: tie
28: suitcase
29: frisbee
30: skis
31: snowboard
32: sports ball
33: kite
34: baseball bat
35: baseball glove
36: skateboard
37: surfboard
38: tennis racket
39: bottle
40: wine glass
41: cup
42: fork
43: knife
44: spoon
45: bowl
46: banana
47: apple
48: sandwich
49: orange
50: broccoli
51: carrot
52: hot dog
53: pizza
54: donut
55: cake
56: chair
57: couch
58: potted plant
59: bed
60: dining table
61: toilet
62: tv
63: laptop
64: mouse
65: remote
66: keyboard
67: cell phone
68: microwave
69: oven
70: toaster
71: sink
72: refrigerator
73: book
74: clock
75: vase
76: scissors
77: teddy bear
78: hair drier
79: toothbrush
EOF
Detection results are published to /yolo_detect_result.
Terminal 4: Execute Task​
ros2 launch simulation_remote_assistant task_manager_node.launch.py
Enter the task command:
Task success: person detected at office door
Data Flow​
office Gazebo AMR
→ /scan + /odom + /tf
→ Cartographer mapping → save pbstream → relocalize
→ Nav2 /navigate_to_pose → office goal (3.087, 0.108)
/camera/color/image_raw
→ 640×640 preprocessing
→ qrb_ros_nn_inference (TFLite float)
→ YOLO postprocessing → /yolo_detect_result
→ task_manager result output
Expected Output​
Terminal 4 outputs:
Navigating to office: (3.087, 0.108)
Navigation target reached, starting detection
Found person at office.
Task finished.
YOLO detects person with a confidence score of approximately 0.52, above the default threshold.
Limitations​
  • The task manager uses YAML keyword matching and does not depend on an LLM or general natural-language understanding.
  • Only pre-configured keywords (office, person) are supported.
  • The default detection threshold of 0.5 may miss persons in some scenes; lowering to 0.3 improves recall but may increase false positives.
  • The simulation is visual and kinematic only. Real sensor accuracy, navigation safety, and occlusion handling are not verified.
