2D LiDAR SLAM
Use QCOM Cartographer for 2D LiDAR SLAM in a Gazebo simulation. Control mapping, freeze, save, map loading, and relocalization through Cartographer service commands.
Build from Source​
cd qrb_ros_simulation
colcon build
Pipeline​
office mini Gazebo AMR
→ /scan + /odom + /tf
→ cartographer_node + cartographer_occupancy_grid_node
→ /qrb_slam_command (mapping / freeze / save / load / relocalize)
→ /map + /tracked_pose + /scan_matched_points2 + /submap_list
Run​
Use the same environment in all terminals:
export ROS_DOMAIN_ID=124
export ROS_LOCALHOST_ONLY=1
source qrb_ros_simulation/install/setup.bash
Terminal 1: Start Gazebo Office Scene​
Run from the desktop terminal:
ros2 launch qrb_ros_sim_gazebo gazebo_robot_base_mini.launch.py \
world_model:=office \
initial_x:=1.0 \
initial_y:=6.0 \
enable_depth_camera:=false
Gazebo starts paused. Click the play button at the bottom-left to start the simulation clock.
Terminal 2: Start Cartographer​
ros2 launch cartographer_ros qrb_2d_lidar_slam.launch.py use_sim_time:=true
Terminal 3: Interactive Service Client​
sh /opt/ros/jazzy/share/cartographer_ros/scripts/qrb_slam_service_request.sh
Select service commands by number:
CommandMeaningDescription
0Start mappingConsume /scan and /odom to build a map
1Finish mappingFreeze the active mapping trajectory
2Save mapSave pbstream and export ROS occupancy map
3Load mapLoad the saved map
4Start localizationStart a localization trajectory against the map
5Validate relocalizationCheck whether localization is ready
Full Workflow​
  1. Enter 0 in Terminal 3 to start mapping
  2. Drive the robot to cover enough static geometry in the environment
  3. Enter 1 to freeze the trajectory, then 2 to save the map
  4. The map is saved to /var/tmp/cartographer_ros/map/map_0.pbstream
  5. Restart Cartographer (press Ctrl+C in Terminal 2 and re-run the launch)
  6. Enter 3 → 4 in Terminal 3 to load the map and start localization
  7. Move the robot to collect enough scans
  8. Enter 5 — expected response: Relocalization Successful, Localization ID: 1
Driving the Robot​
Cartographer services control mapping and localization state only; they do not drive the robot. An independent source must publish /cmd_vel during mapping and localization. Always follow any velocity command with a zero Twist to stop:
# Move forward
ros2 topic pub --rate 10 --times 50 /cmd_vel geometry_msgs/msg/Twist \
'{linear: {x: 0.4}, angular: {z: 0.0}}'
# Stop (Gazebo retains the last velocity command)
ros2 topic pub --times 1 /cmd_vel geometry_msgs/msg/Twist '{}'
Expected Output​
Normal responses for commands 0 through 5:
0: Success. Mapping is Started. Trajectory ID: 0
1: TrajectoryID:0 has finished.
2: Write state to pbstream successfully.
3: Load Map Successfully.
4: Success. Localization is Started. Trajectory ID: 1
5: Relocalization Successful, Localization ID: 1
If the mapping route does not cover enough area, command 5 may return Relocalization Not Ready. — more scan data is needed to connect the localization trajectory to the saved map.
Limitations​
  • Validation used simulated Gazebo LiDAR and odometry; no physical RPLIDAR or robot base was tested.
  • RViz visualization and GPU-specific Cartographer features were not verified.
  • Migration to real hardware requires compatible /odom and /scan topics.
