System Resource Monitor
Monitors system resources via ROS 2 nodes, including CPU, memory, temperature, disk, swap space, and battery monitors.
Run​
Execute in two separate terminals:
Terminal 1 — Start the system monitor node:
ros2 run qrb_ros_system_monitor qrb_ros_system_monitor
Terminal 2 — View monitor topics:
ros2 topic list
# Echo a topic of interest, e.g. CPU usage
ros2 topic echo /cpu
Expected Output​
Terminal 1:
[INFO] [cpu_monitor]: CPU Monitor start
[INFO] [memory_monitor]: Memory Monitor start
[INFO] [temperature_monitor]: Temperature Monitor start
[INFO] [disk_monitor]: DISK Monitor start
[INFO] [swap_monitor]: Swap Monitor start
[INFO] [battery_monitor]: Battery Monitor start
Terminal 2 ros2 topic echo /cpu outputs real-time CPU load data.
Stop​
Press Ctrl + C in each terminal to stop.
