Video Codec
Uses Q900's VPU for hardware H.264/H.265 video encoding and decoding. Transfers frames via DMA-BUF: the encoder compresses raw NV12 frames into MP4, and the decoder reconstructs raw frames from the compressed stream.
Out-of-the-Box​
Step 1: Install​
sudo apt install -y ros-jazzy-qrb-ros-video ros-jazzy-qrb-ros-video-test
Step 2: Prepare Test Data​
The official launch files expect the following filenames. Ensure your test data is named accordingly:
  • Encode input: /data/1920_1080_nv12.yuv (NV12 raw frames, 1920×1080)
  • Decode input: /data/1920_1080.mp4
mkdir -p /data && sudo chmod 777 /data
# Place your test files at the paths and names shown above
Step 3: Encode​
ros2 launch qrb_ros_video encoder_launch.py
The encoder reads /data/1920_1080_nv12.yuv and writes /data/1920_1080_nv12.mp4.
Step 4: Decode​
ros2 launch qrb_ros_video decoder_launch.py
The decoder reads /data/1920_1080.mp4 and writes decoded frames to /dev/null (no display output).
Build from Source​
Step 1: Install Dependencies​
sudo apt install -y build-essential cmake pkg-config \
libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev \
ros-jazzy-qrb-ros-transport-image-type
The official document uses libgstreamer-plugins-base1.0-devs which is a typo; the correct package is libgstreamer-plugins-base1.0-dev.
Step 2: Clone the Repository​
git clone https://github.com/qualcomm-qrb-ros/qrb_ros_video
cd qrb_ros_video
Step 3: Build​
The repository contains two packages (qrb_video_v4l2_lib and qrb_ros_video) which must be built together. File I/O components require BUILD_TESTING=ON:
colcon build --cmake-args -DBUILD_TESTING=ON
Step 4: Run​
The encode and decode commands are identical to the out-of-the-box method. Source install/setup.bash before running to use the source-built version.
Notes​
  • To change input/output paths or resolution, edit the input_file / output_file and width / height parameters in the launch files.
  • The parameter rate_control in the official document table differs from rate-control used in the actual code. Use the spelling found in the launch files.
  • APT version 0.1.2 may segfault on Ctrl+C during decoder cleanup (decoded results are unaffected). Source version 0.1.7 has resolved this.
