Install System to Onboard UFS
This guide explains how to install the system onto the onboard UFS of the Fogwise® AIRbox Q900.
Configuration Note
Fogwise® AIRbox Q900 comes with 128GB onboard UFS.
Entering EDL Mode​
EDL Mode
EDL Mode (Emergency Download Mode) is a low-level recovery mechanism designed by Qualcomm for devices with Qualcomm chipsets. It is used to forcibly flash firmware or repair critical data through the USB interface when the device cannot boot normally due to system crashes, failed firmware updates, or hardware failures.
  1. Press and hold the EDL button before powering on the board.
  2. Release the EDL button after the board is powered on, and it will automatically enter EDL mode.
Entering EDL Mode
① : Press and hold the EDL button using a pin or toothpick
② : Power the board using a 12V DC power adapter
③ : Release the EDL button
④ : Connect the board's USB 3.1 OTG Type-A port to your computer's USB Type-A port using a dual-ended USB Type-A cable
Verifying EDL Mode​
This section describes how to verify EDL mode on both Windows and Ubuntu systems.
  • Download the QDL tool
Go to the Resource Downloads page to download and extract the QDL tool (the QDL tool includes QDL software and QDL drivers).
  • Install QDL Driver
Open the extracted QDL tool folder, locate the qcserlib.inf file, right-click on it, and select the Install option.
  • Verify EDL Mode
After successfully installing the driver, try unplugging and replugging the USB Type-A cable, then observe if the system's Device Manager interface refreshes and shows the Qualcomm HS-USB QDLoader 9008 device.
Windows Device Manager showing Qualcomm HS-USB QDLoader 9008
Installing the System​
This section describes how to install the system onto the onboard UFS of the Fogwise® AIRbox Q900 on both Windows and Ubuntu systems.
Download Files​
Go to the Resource Downloads page to download the boot firmware and system image files.
Go to the Resource Downloads page to download the boot firmware, system image files, and the QDL tool.
Set Environment Variables​
Setting environment variables can simplify subsequent flashing operations and commands.
  1. Press Win + R to open the Run dialog, type sysdm.cpl, and click OK.
Windows Run Dialog
  1. In the System Properties window, click on the Advanced tab, then click the Environment Variables... button.
System Properties Window
  1. In the Environment Variables window, double-click on the Path variable under System variables.
Environment Variables Window
  1. In the Edit Environment Variable window, click the New button, enter the path to the QDL tool, and click OK.
Edit Environment Variable Window
  1. After completing the above steps, reopen the terminal. If you can view the version information using the qdl command, the setup was successful.
Windows$
qdl
Terminal output example:
Usage: qdl [options] <prog.mbn> [<program> <patch> ...]
-d, --debug Print detailed debug info
-v, --version Print the current version and exit
-n, --dry-run Dry run execution, no device reading or flashing
-f, --allow-missing Allow skipping of missing files during flashing
-s, --storage=T Set target storage type T: <emmc|nand|ufs>
-l, --finalize-provisioning Provision the target storage
-i, --include=T Set an optional folder T to search for files
-S, --serial=T Select target by serial number T (e.g. <0AA94EFD>)
-u, --out-chunk-size=T Override chunk size for transaction with T
-t, --create-digests=T Generate table of digests in the T folder
-D, --vip-table-path=T Use digest tables in the T folder for VIP
-h, --help Print this usage info
Example: qdl prog_firehose_ddr.elf rawprogram*.xml patch*.xml
Provision UFS​
Navigate to the qcs9075-provision folder, open a terminal, and use the following command to provision UFS.
PC$
qdl --storage ufs prog_firehose_ddr.elf provision_1_2.xml
Waiting for EDL device
waiting for programmer...
UFS provisioning succeeded
Flash SAIL​
Navigate to the radxa-airbox-q900_noble_gnome_xxx\sail_nor folder, open a terminal, and use the following command to flash SAIL.
PC$
qdl --storage spinor prog_firehose_ddr.elf rawprogram0.xml patch0.xml
flashed "SAIL_HYP" successfully
flashed "SAIL_HYP_BKUP" successfully
flashed "PrimaryGPT" successfully
flashed "BackupGPT" successfully
11 patches applied
Flash System Image​
Navigate to the radxa-airbox-q900_noble_gnome_xxx folder, open a terminal, and use the following command to flash the system image.
PC$
flashed "efi" successfully at 40329kB/s
flashed "system" successfully at 3630kB/s
flashed "xbl_a" successfully
flashed "xbl_b" successfully
flashed "xbl_config_a" successfully
flashed "xbl_config_b" successfully
flashed "aop_a" successfully
flashed "shrm_a" successfully
flashed "uefi_a" successfully
flashed "uefisecapp_a" successfully
flashed "xbl_ramdump_a" successfully
flashed "dtb_a" successfully at 32768kB/s
flashed "tz_a" successfully
flashed "hyp_a" successfully
flashed "devcfg_a" successfully
flashed "cpucp_a" successfully
flashed "multiimgoem_a" successfully
flashed "multiimgqti_a" successfully
flashed "imagefv_a" successfully
flashed "aop_b" successfully
flashed "dtb_b" successfully at 65536kB/s
flashed "imagefv_b" successfully
flashed "shrm_b" successfully
flashed "uefi_b" successfully at 3912kB/s
flashed "uefisecapp_b" successfully
flashed "xbl_ramdump_b" successfully
flashed "tz_b" successfully
flashed "hyp_b" successfully
flashed "devcfg_b" successfully
flashed "cpucp_b" successfully
flashed "multiimgoem_b" successfully
flashed "multiimgqti_b" successfully
flashed "toolsfv" successfully
65 patches applied
partition 1 is now bootable
Using the System​
After completing the above operations, you can use the Fogwise® AIRbox Q900 by following the Quick Start guide.
Other Operation​
Erase System on UFS​
Boot AIRbox Q900 to EDL mode.
Navigate to the radxa-airbox-q900_noble_gnome_xxx/partition_ufs folder, open a terminal, and use the following command to erase UFS.
PC$
qdl --storage ufs ../prog_firehose_ddr.elf rawprogram*_BLANK_GPT.xml
0 patches applied
