Quick Start
This tutorial is designed to help you quickly get started with the Fogwise® AIRbox Q900 product.
Usage Instructions
The AIRbox Q900 comes with a pre-installed system, so you can start using it right away by simply powering it on - no system installation required!
Product Overview​
ProductNo.ViewNo.ViewNo.View
Fogwise® AIRbox Q900①Top View②Side View 1③Side View 2
Fogwise® AIRbox Q900 Product Overview
Hardware Requirements​
You will need to prepare the following hardware:
  • Board: Fogwise® AIRbox Q900
  • Power Supply: 12V DC power adapter
  • Input Devices: Keyboard and mouse
  • Display: Monitor with HDMI cable for system interface
  • Cables:
    • Ethernet cable for network connection
    • USB Type-C cable (optional) for serial console access and command-line interaction
Recommended Accessories
The AIRbox Q900 is powered by a 12V DC power supply. For stable operation with all peripherals, we recommend using a power adapter with at least 5A current.
Hardware Connection​
Connect your monitor, keyboard, mouse, and Ethernet cable to the Fogwise® AIRbox Q900, then power it on using the 12V DC power adapter.
Fogwise® AIRbox Q900 Hardware Connection
① : Connect the monitor to the board using an HDMI cable
② : Connect the router to the board using an Ethernet cable
③ : Connect the mouse or keyboard using the USB Type-A port. If you have a USB hub, you can connect both mouse and keyboard through it
④ : Power the board using the 12V DC power adapter
USB Hub
If you need more USB Type-A ports, you can use a USB hub to easily expand the number of connected USB peripherals, allowing multiple devices to be used simultaneously.
Powering On​
Connect the 12V DC power adapter to the Fogwise® AIRbox Q900. After a successful boot, you'll see the system interface on your monitor.
System Login​
On first boot, you'll need to log in using the default credentials:
UsernamePassword
radxaradxa
Using the System​
After successfully logging in, you can proceed with system configuration and start using your AIRbox Q900.
