Using the System
This guide provides instructions on how to use the system, including system startup, user information, and recommendations for both display and headless modes.
Starting the System​
Power on the Fogwise® AIRbox Q900 using the 12V DC power adapter. If the system boot medium contains a valid operating system, it will start automatically.
System Information​
On first boot, you'll need to log in using the default credentials:
UsernamePassword
radxaradxa
System Usage​
This section provides recommendations for using the board in both display and headless modes to help you get started more easily.
Display Mode​
Display mode involves connecting the board to a monitor using an HDMI cable, allowing you to interact with the system through a graphical user interface using a mouse and keyboard.
This method is straightforward for system operation, as you can configure settings through the system options.
Headless Mode​
Headless mode means using the board without a display. You can access the system via UART login or SSH login.
This method relies on command-line interaction, with more emphasis on using command-line operations to control the system.
