SSH Login
For SSH login, both devices must be on the same local network, and the target device must have the SSH service enabled.
Radxa OS first boot detects whether a display is connected. If a display is connected, SSH service will not be enabled; if no display is connected, SSH service will be enabled automatically.
Install OpenSSH​
SSH remote control requires OpenSSH to be installed. Run the following command in the board's terminal to install it:
Start SSH Service​
Run the following command in the board's terminal to start the SSH service:
sudo systemctl start ssh
Enable SSH Service on Boot​
Run the following command in the board's terminal to enable SSH service on boot:
sudo systemctl enable ssh
Check SSH Service Status​
Run the following command in the board's terminal to check the SSH service status:
sudo systemctl status ssh
The terminal will display information indicating whether the SSH service is enabled on boot and its current status.
Docs: man:sshd(8)
man:sshd_config(5)
Main PID: 518 (sshd)
CPU: 284ms
SSH Remote Control​
You can use either the terminal command line or the Tabby software for SSH remote login.
Open a terminal on another device and enter the following command to log in remotely:
PC$
ssh <user-name>@<ip-address>
# Example
ssh [email protected]
Where <user-name> and <ip-address> are the actual username and IP address of the target device, respectively.
You'll need to confirm the connection by typing yes during the connection process.
After successfully logging in via SSH, you can run commands to control the system through the SSH connection.
Troubleshooting​
If SSH connection fails, follow these steps to diagnose the issue.
1. Verify SSH Service is Running​
On the device, run:
If the service is not running:
On Debian/Ubuntu, ssh is an alias for sshd. If ssh does not work, try sshd.
2. Verify Network Connectivity​
From your PC, ping the device IP to confirm it is reachable:
PC$
ping 192.168.x.x
If ping fails, check:
  • The device and PC are on the same LAN
  • The IP address is correct (avoid using 127.0.0.1)
3. Check Firewall​
Radxa OS uses nftables by default. Run the following to confirm port 22 is not blocked:
To temporarily clear firewall rules for testing:
sudo iptables -F
4. Check Password Authentication Configuration​
Confirm SSH service allows password authentication:
Expected output is PasswordAuthentication yes. If not, edit the configuration:
Ensure the following line exists and is uncommented:
Then restart the SSH service:
sudo systemctl restart ssh
5. Confirm Username and Password​
Radxa OS default username is radxa, password is radxa. If the password is incorrect, reset it via serial connection or display:
sudo passwd radxa
6. Check SSH Logs​
View SSH service logs for detailed error information:
Common errors and their meanings:
Error MessagePossible Cause
Connection refusedSSH service not running or port 22 blocked
Permission deniedWrong password or public key authentication failed
Connection timeoutNetwork unreachable or incorrect IP address
No route to hostNetwork layer routing unreachable
7. Windows SSH Client Issues​
If using a Windows SSH client and encountering problems:
  1. Try Tabby, PuTTY, or MobaXterm as alternatives
  2. Check Windows Firewall is not blocking SSH connections
  3. Confirm password authentication is enabled (not public-key-only)
8. Public Key Authentication Fails​
If you configured SSH public key login but it fails, check server-side permissions:
# .ssh directory permissions should be 700
chmod 700 ~/.ssh
# authorized_keys file permissions should be 600
9. Reset SSH Configuration​
warning
The following operations will interrupt your current SSH connection. If you are accessing remotely, ensure you have an alternative access method (such as serial connection) before proceeding.
# Backup current configuration
# Restore default configuration
# Restart service
Get Help​
If the issue persists, please submit a GitHub Issue with the following information:
  • Output of sudo systemctl status ssh
  • Output of sudo grep -v "^#" /etc/ssh/sshd_config | grep PasswordAuthentication
  • SSH logs: sudo journalctl -u ssh -b --no-pager | tail -30
  • Complete error message when attempting to connect
