UART Login
UART login is a core method in embedded development for interacting with the board through a serial communication interface (UART). Using a serial terminal tool, you can view system logs and perform command-line interactions.
Hardware Connection​
Connect the board's USB Type-C port to your computer's USB port using a USB Type-C cable.
UART Connection Diagram
① : Connect the board's USB Type-C port to your PC's USB port using a USB Type-C cable
② : Power the board using a 12V DC power adapter
UART Login​
UART Communication Parameters
  • Baud Rate: 115200
  • Data Bits: 8
  • Stop Bits: 1
  • Parity: None
  • Flow Control: None
Garbled serial output / board appears not to boot
Some serial terminal applications (for example Tabby) can drop serial data when the device redraws its output frequently, such as a boot menu that keeps redrawing itself, or apt / dpkg style progress output that rewrites the same line or repositions the cursor. The boot log then shows many half-finished lines and repeated messages, the login prompt never appears, and the board looks like it failed to boot or hung — even though the system actually booted normally.
This is a display issue in the terminal application, not a board fault. If you hit it, use a serial terminal that has been verified to render the same output correctly, such as picocom:
Press Ctrl+A Ctrl+X to exit picocom.
Using Tabby​
Download Tabby​
Install Tabby​
Using Tabby​
Serial Port Configuration​
Select Serial Port Template​
Modify Serial Port Parameters​
③ --> Baud rate : Set the baud rate to 115200
Serial Port Device Number
Login via Serial Port​
Serial Port Cannot Be Opened
If you see the error Error: Permission denied, cannot open /dev/ttyUSB*, the current user does not have permission to access the serial port device. First confirm the serial device number corresponding to your board, e.g. /dev/ttyUSB0, then run:
sudo chmod 666 /dev/ttyUSB0
This method may no longer work after a reboot or replugging the device. It is recommended to permanently add the current user to the serial port user group:
After that, log out and log back in for the permission change to take effect.
After a successful connection, press Enter to display the login prompt. Then use the corresponding system username and password to log in (the password will not be displayed as you type; press Enter after entering the password).
Android System Login
Android system login does not require entering user account and password.
Using the Serial Port​
After successfully logging in to the system via the serial port, you can view system logs and run commands to test system functionality.
