SSDMobileNetV2
Host-Side Model Conversion​
Quick Start
Clone the Repository​
Host PC
cd nio12l-model-zoo
Download and Export Model​
Host PC
cd examples/ssd_mobilenet_v2/convert_model
conda activate np8
python download_model.py
python export_onnx.py
Prepare Calibration Data​
Host PC
cd ../../..
python prepare_calibration_data.py path=./datasets/coco128/images/train2017 imgsz=300
Convert Model​
Host PC
python convert_mtk_fp32.py
python convert_mtk_int8.py
After conversion, the following files are generated in examples/ssd_mobilenet_v2/model/:
  • int8/ssd_mobilenet_v2_mtk_int8.tflite
  • fp32/ssd_mobilenet_v2_mtk_fp32.tflite
Device-Side Deployment​
cd nio12l-model-zoo
Get Models​
wget -P examples/ssd_mobilenet_v2/model/int8 https://github.com/Ronin-1124/nio12l-model-zoo/releases/download/v2026.05.11-dla/ssd_mobilenet_v2_int8.dla
wget -P examples/ssd_mobilenet_v2/model/fp32 https://github.com/Ronin-1124/nio12l-model-zoo/releases/download/v2026.05.11-dla/ssd_mobilenet_v2_fp32.dla
Method 2: Convert from Host​
Transfer Models​
Host PC
scp ssd_mobilenet_v2_mtk_int8.tflite <user>@<device>:/path/to/nio12l-model-zoo/examples/ssd_mobilenet_v2/model/int8/
scp ssd_mobilenet_v2_mtk_fp32.tflite <user>@<device>:/path/to/nio12l-model-zoo/examples/ssd_mobilenet_v2/model/fp32/
Convert to DLA​
cd examples/ssd_mobilenet_v2/model/int8
ncc-tflite --arch=mdla2.0 -d ssd_mobilenet_v2_int8.dla ssd_mobilenet_v2_mtk_int8.tflite
cd ../fp32
ncc-tflite --arch=mdla2.0 -d ssd_mobilenet_v2_fp32.dla ssd_mobilenet_v2_mtk_fp32.tflite --relax-fp32
Build​
cd /path/to/nio12l-model-zoo
cmake -S . -B build
cmake --build build -j
Run​
Default uses INT8 model:
./build/ssd_mobilenet_v2_demo
Use FP32 model and specify an image:
./build/ssd_mobilenet_v2_demo --fp32 --image assets/images/bus.jpg
PrecisionTime (ms)FPS
INT810.00699.94
FP3218.29954.65
Results are saved in outputs/ssd_mobilenet_v2/ (vis/ for visualization images, detections/ for JSON).
