YOLO11n-OBB
Host-Side Model Conversion​
Quick Start
Clone the Repository​
Host PC
cd nio12l-model-zoo
Export ONNX​
If you haven't set up the yolo-export environment, create it and install dependencies:
conda create -n yolo-export python
conda activate yolo-export
pip install ultralytics
Host PC
cd examples/yolo11n-obb/convert_model
yolo export model=yolo11n-obb format=onnx opset=13 imgsz=1024
Cut ONNX​
Host PC
conda activate np8
python cut_onnx.py
Prepare Calibration Data​
Host PC
cd ../../..
python prepare_calibration_data.py path=./datasets/dota128/images/train imgsz=1024
Convert Model​
Host PC
python convert_mtk_fp32.py
python convert_mtk_int8.py
After conversion, the following files are generated in examples/yolo11n-obb/model/:
  • int8/yolo11n-obb_mtk_int8.tflite
  • fp32/yolo11n-obb_mtk_fp32.tflite
Device-Side Deployment​
cd nio12l-model-zoo
Get Models​
wget -P examples/yolo11n-obb/model/int8 https://github.com/Ronin-1124/nio12l-model-zoo/releases/download/v2026.05.11-dla/yolo11n-obb_int8.dla
wget -P examples/yolo11n-obb/model/fp32 https://github.com/Ronin-1124/nio12l-model-zoo/releases/download/v2026.05.11-dla/yolo11n-obb_fp32.dla
Method 2: Convert from Host​
Transfer Models​
Host PC
scp yolo11n-obb_mtk_int8.tflite <user>@<device>:/path/to/nio12l-model-zoo/examples/yolo11n-obb/model/int8/
scp yolo11n-obb_mtk_fp32.tflite <user>@<device>:/path/to/nio12l-model-zoo/examples/yolo11n-obb/model/fp32/
Convert to DLA​
cd examples/yolo11n-obb/model/int8
ncc-tflite --arch=mdla2.0 -d yolo11n-obb_int8.dla yolo11n-obb_mtk_int8.tflite
cd ../fp32
ncc-tflite --arch=mdla2.0 -d yolo11n-obb_fp32.dla yolo11n-obb_mtk_fp32.tflite --relax-fp32
Build​
cd /path/to/nio12l-model-zoo
cmake -S . -B build
cmake --build build -j
Run​
Default uses INT8 model with assets/images/boats.jpg:
./build/yolo11n-obb_demo
Use FP32 model:
./build/yolo11n-obb_demo --fp32
Specify images:
./build/yolo11n-obb_demo --image assets/images/boats.jpg
PrecisionTime (ms)FPS
INT8148.1396.75
FP32173.3045.77
Results are saved in outputs/yolo11n-obb/ (vis/ for visualization images, detections/ for JSON).
