Obtain the Source Code
With the authorization of CIX, Risha has released the publicly available part of the CIX SDK on GitLab. Users can conduct secondary development of the O6 through this SDK by themselves.
The CIX SDK only supports compilation on Debian 11 / Ubuntu 22.04 systems. The available storage space of the system should be at least 100GiB.
When the SDK runs in a container, permission issues may occur. It is recommended to use a physical machine or a virtual machine for compilation.
Obtain the repo
Tool
The SDK provides a manifest that is compatible with the repo
tool to help users quickly restore the code file structure locally.
Before downloading the SDK, users should first install this tool on the system they are using. For Debian systems, you can refer to the following commands:
sudo apt-get update
sudo apt-get install repo
For reference on the usage of the repo
command, please refer to the AOSP
documentation.
Pull the Code
Please execute the following commands:
mkdir cix-sdk
cd cix-sdk
repo init https://gitlab.com/cix-linux/linux_repo/cix-manifest.git
# Optionally, init with a specific version of manifest:
# repo init -m release/<version>/default.xml https://gitlab.com/cix-linux/linux_repo/cix-manifest.git
repo sync
After all the code has been downloaded, you can proceed with software compilation.
