Hardware Information
Chip Block Diagram​
System Block Diagram​
Interface Description​
No.DescriptionNo.DescriptionNo.Description
1USB 2.0 (Front Panel)112x Speaker Interface21Power Button
2Audio Interface (Front Panel)12Status Indicator224-Pin Fan Connector
- Supports PWM Speed Control & Monitoring
3Touch Panel Interface13Reset Button23BIOS Flash Socket
4Multi-function Interface (Front Panel)
- Power/LED/Reset
143.5 mm Headphone Jack24CIX P1 SoC
5UART Interface152x 5G Ethernet2540-Pin GPIO Header
6eDP Interface16DisplayPort26LPDDR5
7RTC Battery Holder17HDMI Port27ATX Power Connector
8PCIe x16 Slot (PCIe Gen x4)182x USB 3.2 Type-A28TPM (Unsoldered)
9M.2 M Key Slot192x USB 2.0 Type-A292x MIPI CSI 4-lane
10M.2 E Key 2230 Slot202x USB Type-C
- 20V Type-C Power Delivery (PD) Supported
- Supports DP Alt Mode
Power Button​
Primarily used to control the motherboard's power switch.
  • When the motherboard is powered off, press the power button to start the motherboard
  • When the motherboard is running, a short press triggers a power event that may display a power menu or put the system into suspend mode, depending on OS settings
  • Press and hold the power button for 4 seconds to force a shutdown
Reset Button​
Mainly controls the motherboard's system reset. A short press will restart the system.
Status Indicators​
Two status indicators are onboard.
  • Green LED: Indicates power status
  • Blue LED: Indicates system status
    • Solid blue: BIOS has booted normally
    • Blinking blue: Operating system has booted normally
USB Type-C Ports​
Two USB 3.2 Type-C ports are onboard, supporting data transfer speeds up to 10Gbps. Both support power delivery, and one supports DP Alt Mode.
  • Recommended to use the Radxa PD 65W Power Adapter to power the motherboard
  • Either USB Type-C port can power the motherboard. If two power sources are connected simultaneously, the first PD power source connected will power the motherboard
  • Each USB Type-C port can provide up to 3A of current to external devices
  • USBC0 supports OTG mode, USBC1 supports HOST mode
USB Type-A Ports​
Onboard 2x USB 2.0 Type-A ports, 2x USB 3.2 Type-A ports, and a front panel USB 2.0 interface.
  • USB 2.0 Type-A: Maximum transfer rate of 480Mbps, all USB 2.0 ports share a total of 1.4A current
  • USB 3.2 Type-A: Maximum transfer rate of 10Gbps, each port current limited to 1A
  • USB 2.0 Interface (Front Panel)
PinNameDescriptionPinNameDescriptionPinNameDescription
15V_1Power (+5V)25V_2Power (+5V)3USB_DM_1USB Data-
4USB_DM_2USB Data-5USB_DP_1USB Data+6USB_DP_2USB Data+
7GNDGround8GNDGround9-Reserved/NC
10GNDGround
HDMI Port​
Onboard HDMI Type-A port, supports up to 4K@60Hz. HDMI CEC function is not supported.
DisplayPort​
Onboard DisplayPort, supports up to 4K@120Hz with Multi-Stream Transport (MST) support.
eDP Interface​
Onboard eDP interface with 0.5mm pitch 40-Pin IPEX connector, directly connects to eDP panels, supporting up to 4K@60Hz.
1NCNo Connection2GNDGround33NeDP Lane 3 Negative
43PeDP Lane 3 Positive5GNDGround62NeDP Lane 2 Negative
72PeDP Lane 2 Positive8GNDGround91NeDP Lane 1 Negative
101PeDP Lane 1 Positive11GNDGround120NeDP Lane 0 Negative
130PeDP Lane 0 Positive14GNDGround15AUXPeDP Auxiliary Channel Positive
16AUXNeDP Auxiliary Channel Negative17GNDGround18VDD1Power (+3.3V)
19VDD2Power (+3.3V)20VDD3Power (+3.3V)21VDD4Power (+3.3V)
22NCNo Connection23GNDGround24GNDGround
25GNDGround26GNDGround27NCNo Connection
28GNDGround29GNDGround30GNDGround
31GNDGround32BL_ENBacklight Enable33PWMBacklight PWM Control
34NCNo Connection35NCNo Connection36VBL1Backlight Power
37VBL2Backlight Power38VBL3Backlight Power39VBL4Backlight Power
40NCNo Connection41NCNo Connection42NCNo Connection
43GNDGround
Touch Panel Interface​
Primarily used for touchscreen integration, working with the eDP interface to provide a direct connection for touchscreens.
1ResetTouch Controller Reset (3.3V)2VCCTouch Panel Power (3.3V)3GNDGround Connection
4EINTExternal Interrupt (3.3V)5SDAI2C Data Line for Touch (3.3V)6SCLI2C Clock Line for Touch (3.3V)
7GNDGround Connection8GNDGround Connection
5G Ethernet Ports​
Onboard dual 5G RJ45 Ethernet ports, supporting 10/100/1000/2500/5000 Mbps auto-negotiation.
LEDStateDescription
OrangeSolidLink established (Device connected to network)
GreenBlinkingData transmission in progress (Network activity)
Off-No link detected (Cable unplugged or network issue)
Audio Interface​
Onboard 3.5mm headphone jack and front panel audio interface.
Headphone Jack​
Onboard 3.5mm headphone jack supporting both audio output and input.
Audio Interface (Front Panel)​
Supports front panel audio functionality for PC cases.
1MIC_INLMicrophone Input (Left)2GNDGround3MIC_INRMicrophone Input (Right)
4GNDGround5HP_OUT_RHeadphone Out (Right)6FRONT_MIC_JDFront Panel Mic Jack Detect
7GNDGround8/Reserved/NC9HP_OUT_LHeadphone Out (Left)
10FRONT_HP_JDFront Panel HP Jack Detect
PCIe x16 Slot​
Onboard full-size PCIe x16 slot, supporting PCIe Gen4 x8, compatible with high-performance graphics cards.
  • Power Supply:
    • Maximum 60W for PCIe slot when using ATX power supply
    • Maximum 15W for PCIe slot when using USB Type-C power supply
Fan Connector​
Onboard standard ATX 4-Pin fan connector with PWM control and tachometer support.
Note: The motherboard has silkscreen markings for easy identification and connection.
1GNDGround2VCC12VPower (12V)3TACHTachometer Signal (Fan Speed)
4PWMPWM Control Signal (3.3V)
BIOS Flash Socket​
Onboard BIOS flash chip socket for easy removal or replacement of the BIOS chip.
  • Chip Compatibility: Supports SOP8 flash memory chips
  • Chip Capacity: 8MB (64Mbit)
  • Voltage Level: 1.8V
Notes:
  • The circle corresponds to pin 1, and it is marked with a red circle on the diagram.
  • The triangle corresponds to pin 1, and it is marked with a red triangle on the diagram.
PinNamePinNamePinNamePinName
1ROM_CS2ROM_MISO3ROM_WP4GND
5ROM_MOSI6ROM_CLK7ROM_HOLD8ROM_VCC
Remove / Install BIOS Chip
Non-essential operation, please do not remove the BIOS chip.
To remove and install the BIOS chip, users can refer to the Updating BIOS Firmware Tutorial section of the tutorial on how to use the programmer to update the BIOS firmware.
40-Pin GPIO Header​
Onboard 40-Pin GPIO (General Purpose Input/Output) interface, providing highly flexible hardware expansion capabilities.
Users can connect various sensors, actuators, communication modules, displays, and other embedded peripherals through the 40-Pin GPIO interface, enabling rapid prototyping and functional verification in fields such as IoT, robotics, and industrial automation.
Function3Function2Function1Pin#Pin#Function1Function2Function3
3.3V
1
2
5V
GPIO062I2C4_SDA
3
4
5V
GPIO061I2C4_CLK
5
6
GND
GPIO071
7
8
UART3_TXDGPIO105
GND
9
10
UART3_RXDGPIO106
GPIO095PWM0UART0_TXD
11
12
GPIO091I2S4_SCK_LB
GPIO096PWM1UART0_RXD
13
14
GND
GPIO099FAN_OUT0UART1_TXD
15
16
UART1_RXDFAN_TACH0GPIO100
3.3V
17
18
GPIO044
SPI2_MOSIGMAC1_TXD3GPIO141
19
20
GND
SPI2_MISOGMAC1_TXD0GPIO138
21
22
GPIO045
SPI2_CLKGMAC1_TX_CLKGPIO142
23
24
GPIO139SPI2_CS0
GND
25
26
GPIO140SPI2_CS1
GPIO056I3C0_SDAI2C2_SDA
27
28
I2C2_CLKI3C0_SCLGPIO055
GPIO076I2S2_DATA_IN1
29
30
GND
GPIO078I2S2_DATA_OUT1
31
32
GPIO046
GPIO079I2S2_DATA_OUT2
33
34
GND
I2S4_WS_LBGPIO092
35
36
GPIO090I2S4_MCLK_LB
GPIO080I2S2_DATA_OUT3
37
38
GPIO093I2S4_DATA_IN_LB
GND
39
40
GPIO094I2S4_DATA_OUT_LB
ATX Power Connector​
Onboard 24-pin ATX-compatible power connector for standard ATX power supply compatibility.
3GNDGround5GNDGround7GNDGround
8PWR_OKPower Good (Logic High: 3.3V or 5V)95VSBStandby Power (+5V, Always On)1012VPower (+12V)
1112VPower (+12V)13NCNo Connection14NCNo Connection
15GNDGround16PS_ONPower On (Active Low)17GNDGround
18GNDGround19GNDGround20NCNo Connection
21NCNo Connection22NCNo Connection23NCNo Connection
24GNDGround
M.2 M Key Slot​
Onboard M.2 M Key slot supporting PCIe Gen4 x4, compatible with 2230/2242/2260/2280 M.2 NVMe SSDs for storage expansion.
M.2 E Key Slot​
Onboard M.2 E Key slot supporting PCIe Gen4 x2, compatible with 2230 form factor WiFi/Bluetooth modules.
Multi-function Interface (Front Panel)​
Onboard multi-function interface for front panel power button, reset button, and status indicators.
1SSD_LED+SSD Activity LED (+)2PWR_LED+Power LED (+)3SSD_LED-SSD Activity LED (-)
4PWR_LED-Power LED (-)5RESET-Reset Switch (-)6PWR_ONPower On Signal
7RESET+Reset Switch (+)8PWR_GNDPower Ground9RSV(5V)Reserved (5V Power)
10NCNo Connection
UART Interfaces​
Four dedicated UART interfaces for various debugging purposes.
  • UART2: BIOS and OS debug logs
  • UART4: Power management, voltage and frequency monitoring
  • UART5: Secure BootROM debug logs
  • EC UART: Onboard embedded controller debug logs
UART_x Pinout​
1GNDGround2UART_TXUART Transmit (3.3V)3UART_RXUART Receive (3.3V)
BOOT Pinout​
1BOOT_STRAPBoot Strap Pin2GNDGround
MIPI CSI Interface​
Onboard dual MIPI CSI 4-lane interfaces for connecting camera modules.
RTC Battery Holder​
Onboard RTC battery holder for CR1220 coin cell battery, providing continuous clock signal and power management functionality.
Note: Removing the RTC battery will not immediately clear the BIOS settings; however, if there is no battery and the system is fully powered off and then powered on again, the firmware may detect an RTC power loss and automatically restore the BIOS default values.
