Simulate YOLOv5 Segmentation Inference
This document demonstrates how to use the rknn-toolkit2 to simulate inference of the YOLOv5 segmentation model on an x86 PC without a development board. For the required environment setup, refer to RKNN Installation.
Prepare the Model
This example uses a pretrained ONNX model from the rknn_model_zoo. The model is converted and simulated on the PC.
  • If using conda, activate the rknn conda environment first:
    X86 Linux PC
    conda activate rknn
  • Download the yolov5s-seg.onnx model:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5_seg/model
    # Download the pretrained yolov5s-seg.onnx model
    bash download_model.sh
    If you encounter network issues, visit this page to download the model manually and place it in the corresponding folder.
  • Rename the ONNX model file to rknn format (only for PC simulation purposes):
    X86 Linux PC
    cp yolov5s-seg.onnx yolov5s-seg.rknn
  • (Optional) Convert the ONNX model to yolov5s-seg.rknn using rknn-toolkit2:
    X86 Linux PC
    cd rknn_model_zoo/examples/yolov5_seg/python
    # Example:
    # python3 convert.py ../model/yolov5s-seg.onnx rk3588 i8 ../model/yolov5s-seg.rknn
    Parameter explanation:
    • <TARGET_PLATFORM>: Target NPU platform, such as rk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126.
    • <dtype>: Quantization type (i8 for int8, fp for fp16). Default is i8.
    • <output_rknn_path>: Path to save the RKNN model. Defaults to the same directory as the ONNX model with the filename yolov5s-seg.rknn.
ONNX Model Inference on PC
Run the inference script:
X86 Linux PC
python3 yolov5_seg.py --model_path ../model/yolov5s-seg.onnx --img_show
Example output:
Results
person @ (212 242 285 510) 0.871
person @ (111 240 223 535) 0.850
person @ (472 233 559 519) 0.831
bus @ (97 134 549 458) 0.799
person @ (80 328 125 517) 0.470
RKNN Model Simulation Inference on PC
  • Install required dependencies via pip3:
    X86 Linux PC
    pip3 install torchvision==0.19.0 pycocotools
  • Modify the rknn_model_zoo/py_utils/rknn_executor.py file as follows (make a backup of the original file):
    Python Code
    from rknn.api import RKNN
    class RKNN_model_container():
    rknn = RKNN()
    DATASET_PATH = '../../../datasets/COCO/coco_subset_20.txt'
    onnx_model = model_path[:-4] + 'onnx'
    rknn.config(mean_values=[[0, 0, 0]], std_values=[[255, 255, 255]], target_platform=target)
    rknn.load_onnx(model=onnx_model)
    rknn.build(do_quantization=True, dataset=DATASET_PATH)
    rknn.init_runtime()
    self.rknn = rknn
    def run(self, inputs):
    pass
    else:
    inputs = [inputs]
    return result
    def release(self):
    self.rknn.release()
    self.rknn = None
  • Run the simulation inference script:
    X86 Linux PC
    python3 yolov5_seg.py --target <TARGET_PLATFORM> --model_path <RKNN_MODEL_PATH> --img_show
    # Example:
    # python3 yolov5_seg.py --target rk3588 --model_path ../model/yolov5s-seg.rknn --img_show
    Parameters:
    • --target: Specifies the NPU platform for simulation. Options include rk3562, rk3566, rk3568, rk3576, rk3588, rk1808, rv1109, rv1126.
    • --model_path: Path to the RKNN model to simulate.
Example output:
Results
person @ (213 239 284 516) 0.882
person @ (109 240 224 535) 0.869
person @ (473 231 560 523) 0.845
bus @ (97 136 548 459) 0.821
person @ (80 328 124 519) 0.499
  • The simulation inference result (only simulates NPU computation; actual performance and accuracy depend on inference on the target board):
