Quick Start
Package Contents​
rock4a package
Standard package for ROCK 4A includes the following items:
  • ROCK 4A mainboard
  • Anti-static bag
  • PP plastic case
  • Toothpaste box
To get started with ROCK 4A/4B/4A+/4B+/4SE, you will also need the following equipment:
  • A 12V/2A or higher power PD adapter. ROCK 4B/4B+/4SE also support PoE power supply. For more power supply details, please refer to Power Supply Options.
  • An HDMI cable and an HDMI-compatible display, recommended resolution of 1080P or higher, with 4K display providing the best experience.
  • A USB mouse and keyboard set. Common USB input devices support plug-and-play.
  • An Ethernet cable is required for system updates.
It is recommended to use the official Radxa PD30W Adapter.
Optional peripherals that can enhance the basic functionality of ROCK 4A/4B/4A+/4B+/4SE:
  • Heat sink
  • M.2 NVMe SSD. It is recommended to install the operating system on an M.2 NVMe SSD.
Installing the Operating System​
Refer to the Installation Guide section to install the operating system.
Wiring and Power On​
  1. Connect any HDMI output port of ROCK 4A/4B/4A+/4B+/4SE to an HDMI display using an HDMI cable.
rock4 hdmi
  1. Connect the USB mouse and keyboard to any USB 2.0 or 3.0 port on the ROCK 4A/4B/4A+/4B+/4SE.
rock4 usb
  1. Connect an Ethernet cable to the Ethernet port.
rock4 ethernet
  1. If you have an M.2 Wi-Fi module or SSD, install and secure it using the provided M.2 screws.
  2. Plug the power adapter into the power port of the ROCK 4A/4B/4A+/4B+/4SE. The device will power on, and the power indicator light will turn on.
rock4 pwr
The entire boot process from power-on to system startup takes about 40 seconds, after which you'll see the desktop interface.
