Replacing the 32-bit Root Filesystem
Compiling Debian 11 armhf Root Filesystem​
Install Required Tools​
PC:~$ sudo apt install -y debootstrap
Create Root Filesystem Directory​
PC:~$ mkdir rootfs
PC:~$ cd rootfs
Generate Debian 11 armhf Root Filesystem Using debootstrap​
PC:~$ sudo debootstrap --arch armhf bullseye rootfs http://mirrors.tuna.tsinghua.edu.cn/debian
Switch to armhf Root Filesystem​
sudo chroot rootfs bash
Install Required Packages in armhf Root Filesystem​
apt update
apt install -y sudo usbutils network-managerfdisk \
vim nano openssh-server iputils-ping wget curl \
iproute2 dialog locales kmod zip unzip u-boot-tools initramfs-tools
Create User​
adduser radxa
gpasswd -a radxa sudo
Flash Debian 11 arm64 Image to SD Card or eMMC Module​
Record Target Device Information​
Confirm Target Device​
Insert the SD card or eMMC module with the newly flashed Debian 11 arm64 into your local PC and mount it
PC:~$ lsblk
sdb 8:16 1 29.3G 0 disk
├─sdb1 8:17 1 16M 0 part
└─sdb2 8:18 1 5.1G 0 part
From this, we can see our target device is /dev/sdb2
Record UUIDs​
PC:~$ sudo blkid /dev/sdb2
/dev/sdb2: LABEL="rootfs" UUID="8bf96d05-7c97-42fc-863c-95e3e7603ef4" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="rootfs" PARTUUID="474d4c1f-53da-447c-bab4-334abe0d5753"
PC:~$ sudo blkid /dev/sdb1
/dev/sdb1: LABEL_FATBOOT="config" LABEL="config" UUID="4AD5-9369" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="config" PARTUUID="8d24a074-ea49-4d24-a17c-82dd88776fa2"
Replace Root Filesystem​
Mount Target Device​
PC:~$ sudo mount /dev/sdb2 /data2
PC:~$ cd /data2
Navigate to the mounted root filesystem, back up the boot directory, delete and replace the root filesystem, then restore the boot directory to the new root filesystem
PC:/data2$ sudo cp -r ./boot ~/
PC:/data2$ sudo rm -rf *
PC:/data2$ sudo cp -av /path/to/rootfs/* ./
PC:/data2$ sudo cp -av ~/boot/* ./boot/
Modify fstab​
PC:/data2$ cat ./etc/fstab
### UNCONFIGURED FSTAB FOR BASE SYSTEM
Update the fstab file with the previously recorded UUIDs
PC:/data2$ sudo cat ./etc/fstab
UUID=8bf96d05-7c97-42fc-863c-95e3e7603ef4 / ext4 defaults 0 1
UUID=4AD5-9369 /config vfat defaults,x-systemd.automount 0 2
Unmount​
radxa@radxa:/data2$ cd
radxa@radxa:~$ sudo umount /data2
Verify 32-bit Root Filesystem​
Boot the System​
Insert the SD card or eMMC with the replaced rootfs into the board and power it on.
Verify Current Root Filesystem is 32-bit​
radxa@rock-4se:~$ sudo apt-get install file -y
radxa@rock-4se:~$ file /bin/ls
/bin/ls: ELF 32-bit LSB pie executable, ARM, EABI5 version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, Build
This confirms we have successfully replaced the rootfs with a 32-bit version
