eMMC / UFS Module Interface
The Radxa ROCK 4D features an onboard eMMC/UFS combo module interface that supports both eMMC and UFS modules, which can be used as a system boot drive or for expanding storage capacity.
danger
Do not use untested third-party UFS or eMMC modules. Some third-party modules may short the SBC and cause permanent hardware damage, and such damage is not covered by warranty.
Since the ROCK 4D comes with SPI Nor Flash by default, eMMC modules are not supported. This guide only covers the use of UFS modules.
User Guide​
eMMC modules are suitable for small capacity storage (8-128GB), while UFS modules are designed for larger capacity storage (64GB-1TB).
  • Expanding Storage
You can directly install a UFS module into the eMMC/UFS module interface, then boot the system and use the lsblk command to verify if the UFS module is recognized.
  • As a System Boot Drive
You can refer to the Install System to UFS Module tutorial to install the system image onto the UFS module. After installation, insert the UFS module into the eMMC/UFS module interface and test if the system boots normally.
The ROCK 4D is recommended to be used with our Radxa UFS Module.
caution
UFS Module Installation Steps:
  1. Ensure the notched corner of the UFS module aligns with the eMMC/UFS module interface on the ROCK 4D
  2. Make sure the bottom slot interface of the UFS module is properly aligned with the eMMC/UFS module interface on the ROCK 4D
  3. Gently press down on one end of the UFS module until you hear a click, then repeat the process on the other end to ensure the UFS module is securely installed.
Interface Specifications​
Pin#NamePin#NamePin#NamePin#Name
1GND17GND33FSPI0_D6 / EMMC_D649GND
2FSPI0_D5 / EMMC_D518GND34GND50GND
3GND19GND35GND51VCC1V2_UFS_VCCQ_S0
4FSPI0_D4 / EMMC_D420VCCIO_FLASH36UFS_TX_D0P52VCC1V2_UFS_VCCQ_S0
5GND21VCCIO_FLASH37UFS_TX_D0N53VCC1V8_UFS_VCCQ2_S0
6FSPI0_D0 / EMMC_D022VCC_3V3_S338GND54VCC1V8_UFS_VCCQ2_S0
7GND23VCC_3V3_S339UFS_TX_D1P55VCC_UFS_S0
8FSPI0_CLK / EMMC_CLK24GND40UFS_TX_D1N56VCC_UFS_S0
9GND25FSPI0_RSTN / EMMC_CMD41GND57UFS_RSTn
10FSPI0_D3 / EMMC_D326GND42UFS_REFCLK58GND
11GND27FSPI0_D2 / EMMC_D243GND59UFS_RX_D1N
12FSPI0_CSNO / EMMC_RSTN28GND44NC60UFS_RX_D1P
13GND29FSPI0_D1 / EMMC_D145NC61GND
14GND30GND46UFS_PLUG62UFS_RX_D0N
15FSPI0_DQS / EMMC_STRB31FSPI0_D7 / EMMC_D747NC63UFS_RX_D0P
16GND32GND48NC64GND
