FPC Connector
The Radxa ROCK 4D features an onboard FPC (Flexible Printed Circuit) connector that supports PCIe 2.1 standard with a single lane (x1) for high-speed data expansion.
You can connect a PCIe to M.2 M Key HAT to the FPC interface and use it with an M.2 NVMe SSD to boot the system or expand storage capacity.
This page describes the NVMe SSD use case; it does not establish compatibility with other M.2 PCIe devices, such as accelerator cards. Before using another device, check the device and adapter keying, supply voltage, and peak power requirements. Although the pin table below lists 5V supply pins, it does not specify the current or power available from this connector. Also verify PCIe enumeration, driver loading, and the intended application on the target system image.
User Guide​
To use an M.2 NVMe SSD, you need to connect it to the ROCK 4D's FPC interface using a PCIe to M.2 M Key HAT.
  • Expanding Storage
Insert the M.2 NVMe SSD into the PCIe to M.2 M Key HAT, then connect the HAT to the ROCK 4D's FPC interface. Use the lsblk command to verify if the NVMe SSD is recognized.
  • As a System Boot Drive
Refer to the Install System to NVMe SSD tutorial. After installation, insert the NVMe SSD into the PCIe to M.2 M Key HAT, then connect the HAT to the ROCK 4D's FPC interface to test if the system boots normally.
Interface Specifications​
Pin#NamePin#NamePin#Name
1VCC5V0_SYS_S57PCIE0_SOC_RXP13PCIE0_PWREN_H
2VCC5V0_SYS_S58PCIE0_SOC_RXN14PCIE0_WAKEN_M0
3GND9GND15PCIE0_CLKREQn_M0
4PCIE0_SOC_REFCLKP10PCIE0_SOC_TXP16PCIE0_PERSTn
5PCIE0_SOC_REFCLKN11PCIE0_SOC_TXN
6GND12GND
