Gigabit Ethernet (with PoE Support) Interface
The Radxa ROCK 4D features one onboard Gigabit Ethernet port with PoE (Power over Ethernet) capability. However, to utilize PoE power delivery, you'll need to purchase and install a PoE HAT expansion board separately.
User Guide​
Ethernet​
Connect the ROCK 4D's Gigabit Ethernet port to your router using an Ethernet cable. Under normal circumstances, the port's LED indicators will blink, indicating a successful network connection.
Checking Network Interface Status​
Use the ip a command in the terminal to view network interface status and IP address information.
radxa@radxa-4d$
ip a
The terminal will display output similar to the following, where 192.168.2.106 is the IP address assigned by your router:
inet6 ::1/128 scope host noprefixroute
2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 5a:cb:6b:3c:ed:ae brd ff:ff:ff:ff:ff:ff
inet 192.168.2.106/24 brd 192.168.2.255 scope global dynamic noprefixroute end0
valid_lft 2652sec preferred_lft 2652sec
inet6 fdaa::dd7/128 scope global dynamic noprefixroute
valid_lft 2494sec preferred_lft 2494sec
inet6 240e:3b7:3246:54f0::dd7/128 scope global dynamic noprefixroute
inet6 240e:3b7:3246:54f0:4732:d5f3:184e:7827/64 scope global dynamic noprefixroute
valid_lft 236440sec preferred_lft 150040sec
inet6 fdaa::9d81:8d0f:7ee4:5760/64 scope global noprefixroute
inet6 fe80::379f:ead8:706f:5d6/64 scope link noprefixroute
PoE (Power over Ethernet)​
To use PoE functionality on the ROCK 4D, you'll need both a PoE HAT and a PoE-enabled Ethernet switch.
Once you have these components, connect the ROCK 4D's Gigabit Ethernet port to the PoE switch using an Ethernet cable.
Under normal operation, the motherboard's power indicator will light up, indicating proper power delivery, and the Ethernet port's LED will blink, showing an active network connection.
A PoE Ethernet switch can perform both Ethernet data switching and provide power to PoE-capable devices.
Interface Specifications​
Pin#NamePin#Name
1PHY0_MDI0+11TR0
2PHY0_MDI0-12TR1
3PHY0_MDI1+13TR2
4GND14TR3
5GND15PHY0_G_LED+
6PHY0_MDI1-16PHY0_G_LED-
7PHY0_MDI2+17PHY0_Y_LED+
8PHY0_MDI2-18PHY0_Y_LED-
9PHY0_MDI3+19GND
10PHY0_MDI3-20GND
