Hardware Information
Chip Block Diagram​
System Block Diagram​
Interface Information​
For interfaces that support external devices, click on the interface description to view the usage tutorial.
#DescriptionQty#DescriptionQty#DescriptionQty
①USB Type-C Port1⑩PoE Port1⑲MIPI CSI Interface1
②User LED1⑪Maskrom Button1⑳HDMI 2.1 Port1
③Power LED1⑫USB 2.0 Type-A Ports2㉑Recovery Pins1
④Power Button1⑬Rockchip RK3576(J)1㉒UFS Module Interface1
⑤FPC Connector1⑭USB 3.0 Type-A Ports
Up:USB 3.0 Type-A OTG
Down:USB 3.0 Type-A HOST
2㉓RTC Interface1
⑥WiFi 6 & Bluetooth 5.41⑮SPI NOR Flash1㉔eMMC Module Interface1
⑦Antenna Connector1⑯Gigabit Ethernet (PoE)1㉕MIPI CSI Interface1
⑧40-Pin GPIO Header1⑰Fan Connector1㉖microSD Card Slot1
⑨LPDDR5 RAM1⑱Headphone Jack1㉗MIPI DSI Interface1
  • User LED
The user LED will blink when the system is booting up normally.
  • Power LED
The power LED will light up when the system is powered on and functioning correctly.
  • Power Button
Short press to power on or access power menu options; long press to power off.
  • LPDDR5 RAM
Available in 2GB / 4GB / 8GB / 16GB capacity options.
  • Rockchip RK3576(J)
The Radxa ROCK 4D is available in two SoC versions: Commercial-grade ROCK 4D based on RK3576 and Industrial-grade ROCK 4D based on RK3576J.
