MIPI CSI Interface
The Radxa ROCK 4D features 2 onboard MIPI CSI interfaces for connecting camera modules:
  • 1 x 4-lane MIPI CSI: Radxa 31-Pin / 0.3mm pitch FPC connector (model FH35C-31S-0.3SHW(50))
  • 1 x 2-lane MIPI CSI: Raspberry Pi 15-Pin / 1.0mm pitch FPC connector (model FPC1030-15S-TAG; pin-compatible with the official Raspberry Pi 15P CSI camera standard)
The 4-lane MIPI CSI interface supports higher resolution camera modules, allowing users to choose based on their specific requirements.
Interface Overview​
InterfaceLanesConnector TypeConnector ModelNotes
4-lane CSI4Radxa 31-Pin / 0.3mm FPCFH35C-31S-0.3SHW(50)For high-resolution cameras (Camera 4K)
2-lane CSI2Raspberry Pi 15-Pin / 1.0mm FPCFPC1030-15S-TAGPin-compatible with the official Raspberry Pi 15P CSI camera standard
ROCK 4D 2-lane MIPI CSI InterfaceROCK 4D 4-lane MIPI CSI Interface
Supported Cameras​
BoardCSI CameraNotes
ROCK 4DCamera 4K
ROCK 4DCamera 13M 214Color preview is being adapted
ROCK 4DCamera 8M 219Color preview is being adapted
Hardware Connection​
Use the board's MIPI CSI interface to connect the camera. The connection method is as follows: taking the 4-lane MIPI CSI interface connecting Camera 4K as an example
①: Connect to the board's MIPI CSI interface, with the gold fingers (metal contacts) facing towards the board
②: Connect to the camera's interface, with the gold fingers (metal contacts) facing towards the camera
Camera 4K MIPI CSI Interface
Software Enable​
Enter rsetup command in the terminal command line, and use the Rsetup tool to configure camera options.
rsetup
  1. Use the arrow keys to select the Overlays option, then press Enter to confirm the selection.
  1. Use the arrow keys to select the Manage overlays option, then press Enter to confirm the selection.
  1. Use the arrow keys to select the corresponding Camera option, press the space key to enable the function (indicated by *), then press Enter to confirm the selection.
  2. Restart the system for the configuration to take effect.
Interface Specifications​
  • 4-lane MIPI CSI Interface Specifications (Radxa 31-Pin / 0.3mm FPC)
    • Model: FH35C-31S-0.3SHW (50)
    • Pin Pitch: 0.3mm
    • Pin Count: 31 Pin
Pin#NamePin#NamePin#Name
1GND12MIPI_DPHY_CSI1_RX_D1P23MIPI_CSI0_PDN1_H
2MIPI_DPHY_CSI1_RX_D3N13GND24I2C5_SCL_M3_MIPI_CSI1
3MIPI_DPHY_CSI1_RX_D3P14MIPI_DPHY_CSI1_RX_D0N25I2C5_SDA_M3_MIPI_CSI1
4GND15MIPI_DPHY_CSI1_RX_D0P26MIPI_CSI0_PDN2_H
5MIPI_DPHY_CSI1_RX_D2N16GND27CAM1_RST_L
6MIPI_DPHY_CSI1_RX_D2P17MIPI_DPHY_CSI1_CLKN28VCC_3V3_S0
7GND18MIPI_DPHY_CSI1_CLKP29VCC_3V3_S0
8MIPI_DPHY_CSI2_RX_CLKN19GND30VCC5V0_DEVICE_S0
9MIPI_DPHY_CSI2_RX_CLKP20MIPI_DPHY_CSI1_CAM_CLKOUT31VCC5V0_DEVICE_S0
10GND21GND32GND
11MIPI_DPHY_CSI1_RX_D1N22MIPI_DPHY_CSI0_CAM_CLKOUT33GND
