MIPI DSI Interface
The Radxa ROCK 4D features one onboard MIPI DSI interface for connecting displays, supporting resolutions up to 2K.
ROCK 4D MIPI DSI Interface
Supported Displays​
List of displays tested and confirmed working with ROCK 4D:
ModelResolution
Radxa Display 8 HD800×1280
User Guide​
To connect a display using the MIPI DSI interface, the ROCK 4D requires a dedicated FPC cable (FPC cable specification: 39-pin 0.3mm SBC to 40-pin 0.5mm Display).
  • Cable Connection Guide
①. Connect to the ROCK 4D's MIPI DSI interface with the gold fingers (metal contacts) facing toward the mainboard.
②. Connect to the display's interface with the gold fingers (metal contacts) facing toward the display.
MIPI DSI Connection Diagram
Enabling the Display​
  1. Open a terminal and enter the rsetup command to configure display options:
radxa@radxa-4d$
rsetup
  1. Use the arrow keys to select the Overlays option, then press Enter.
Rsetup Overlays Menu
  1. Select Manage overlays and press Enter.
Manage Overlays Menu
  1. Use the arrow keys to select Enable Radxa Display 8 HD, press Space to check the option, then press Enter to confirm.
An asterisk * in the checkbox indicates the option is enabled.
  1. Reboot the system for the changes to take effect. The display should now work properly.
Interface Specifications​
Pin#NamePin#NamePin#Name
1LCD_3V315GND29GND
2LCD_3V3/VCC_1V8_S016MIPI_DPHY_DSI_TX_D2N30LCD_3V3
3NC17MIPI_DPHY_DSI_TX_D2P31LCD_3V3
4LCD_RESET_118GND32GND
5NC19MIPI_DPHY_DSI_TX_D3N33GND
6GND20MIPI_DPHY_DSI_TX_D3P34VCC_LEDK2
7MIPI_DPHY_DSI_TX_D0N21GND35VCC_LEDK2
8MIPI_DPHY_DSI_TX_D0P22GND36NC
9GND23TP_RST_LCD37NC
10MIPI_DPHY_DSI_TX_D1N24VCC_TP38VCC_LEDA2
11MIPI_DPHY_DSI_TX_D1P25TP_INT_LCD39VCC_LEDA2
12GND26TP_SDA_LCD40GND
13MIPI_DPHY_DSI_TX_CLKN27TP_SCL_LCD41GND
14MIPI_DPHY_DSI_TX_CLKP28GND
