RKDevTool Usage
RKDevTool is a software developed by Rockchip for USB flashing on Windows/Linux/macOS platforms, designed to simplify and accelerate the development and debugging process for Rockchip series chips.
RKDevTool Installation​
  • Install Drivers
Download and extract the DriverAssitant file.
Locate the DriverInstall.exe file and run it as administrator:
  • To install drivers: Click the Install Driver button
  • To uninstall drivers: Click the Uninstall Driver button
If you have installed a different version of the driver before, please uninstall it first before installing the new one.
RKDevTool Driver Installation
  • Download RKDevTool
Download the RKDevTool software. After downloading, extract the files. You'll find RKDevTool.exe as the main executable. Double-click it to launch the application.
RKDevTool Usage​
In Rockchip platform development, RKDevTool is a commonly used flashing tool, with Maskrom mode and Loader mode being the two key device boot modes.
  • Loader mode requires a valid bootloader to be present in the storage medium.
  • MaskROM mode does not require a valid bootloader in the storage medium.
Maskrom/Loader Modes​
We primarily recommend using RKDevTool in Maskrom mode because it allows direct flashing via USB connection, while Loader mode requires a valid bootloader to be present in the storage medium.
The following instructions use the Radxa ROCK 4D as the demonstration board. Note that some products might not have a dedicated Recovery interface for entering Loader mode and might only have a Maskrom mode button.
Entering Maskrom Mode​
Refer to the Hardware Use: Maskrom Button tutorial.
Entering Loader Mode​
Refer to the Hardware Use: Recovery Pins tutorial.
