Install System to eMMC Module
ROCK 4D Version
The ROCK 4D version with onboard SPI Flash cannot boot the Yocto project-built system from eMMC.
System Image​
You need to prepare the core-image-minimal-rockchip-rk3576-rock-4d.rootfs.wic image file built by the Yocto Project in advance.
Build System
For Yocto Project build steps, please refer to the Build System documentation.
Hardware Preparation​
You need to prepare the following hardware devices in advance:
  • eMMC module
  • Radxa eMMC/UFS Module Reader
Install System​
You can use Balena Etcher software to install the system image to the eMMC module.
warning
Installing the system will format the eMMC module. Please backup important data in advance!
Balena Etcher
For Balena Etcher installation and usage, please refer to the Etcher Usage tutorial.
Hardware Connection​
Insert the eMMC module into the Radxa eMMC/UFS Module Reader, then insert the Radxa eMMC/UFS Module Reader into the computer.
caution
eMMC Module Installation Steps:
  1. Ensure the notch on the eMMC module aligns with the interface direction of the module reader
  2. Make sure the slot interface at the bottom of the eMMC module aligns with the module reader's interface
  3. Gently press one end of the eMMC module until you hear a "click" sound, indicating successful installation. Use the same method to press the other end to ensure the eMMC module is properly installed.
Flash System Image​
Follow the steps below to flash the system image to the eMMC module.
  1. Select System Image
Click the Flash from file option and select the system image file built by the Yocto Project.
  1. Select Storage Device
Click the Select target option and select the eMMC module device.
  1. Start Flashing
Click the Flash! option to start flashing the system image to the eMMC module.
Wait for system installation to complete
Wait for system verification to complete
Boot System​
Install the eMMC module to the eMMC module interface of ROCK 4D, connect a display, and finally power the board using a power adapter.
