Auto Login
Auto login automatically logs in to the system username at startup without requiring manual password entry.
After enabling auto login, you may experience a black screen when using VNC remote control. It is recommended to enable auto login only for users with a direct display connection.
If you need to use VNC remote control, you may want to disable the auto login feature.
Enable Auto Login​
Enter the rsetup command in the terminal to enable auto login using the Rsetup tool:
radxa@radxa-4d$
rsetup
  1. Use the arrow keys to select the User Settings option, then press Enter to confirm.
  1. Use the arrow keys to select the Configure auto login option, then press Enter to confirm.
  1. Use the arrow keys to select the Enable auto login option, press Space to check gdm.service, then press Enter to confirm.
A * in the checkbox indicates the option is enabled.
  1. Reboot the system for the auto login configuration to take effect.
