Headless Mode
Headless Mode refers to using the Radxa ROCK 4D without a display, controlling the board through Serial/UART, SSH, or VNC. This mode is suitable for users with some development experience.
Control Method: Obtain the ROCK 4D's IP address via serial debugging, then configure the corresponding SSH and VNC environments to remotely control the ROCK 4D through SSH or VNC.
  • Serial Debugging: Refer to the Serial Debugging tutorial for detailed steps
  • SSH Remote Login: Refer to the Remote Login tutorial for detailed steps
  • VNC Remote Login: Refer to the VNC Remote Login tutorial for detailed steps
You can follow the Serial Debugging and Remote Login tutorials to connect to the ROCK 4D.
Control Interface​
In headless mode, Serial/SSH control uses command-line interface, while VNC control provides a graphical interface.
Command Line Mode​
Serial control requires a physical cable connection, while SSH control only requires both devices to be on the same local network.
① : Open a Linux terminal and log in to ROCK 4D via Serial
② : Open a Linux terminal and log in to ROCK 4D via SSH
Graphical Interface Mode​
VNC control requires both the controlling and controlled devices to be on the same local network.
VNC Remote Login Successful
