Network Configuration
Configure wired and wireless networks through both graphical interface and command line.
Wired Network​
Connect the Radxa ROCK 4D's Gigabit Ethernet port to your router using an Ethernet cable. After a successful connection, the router will automatically assign an IP address to the ROCK 4D.
① Click on the network icon
② Select the Details option to view detailed network connection information, such as IP address, subnet mask, gateway address, etc.
The IP address 192.168.2.106 is assigned by the router.
Wireless Network​
Connect to a wireless router using the ROCK 4D's onboard WiFi. After a successful connection, the router will automatically assign an IP address to the ROCK 4D.
The ROCK 4D has two onboard antenna connectors. You need to install the antennas in these positions; otherwise, the WiFi signal will be very poor.
② Click the Connect button next to the WiFi network name you want to connect to
③ Enter the WiFi password and follow the prompts to complete the connection
After a successful connection, select the Details option to view detailed network connection information, such as IP address, subnet mask, gateway address, etc.
The IP address 192.168.31.53 is assigned by the router.
