Simulate YOLOv5 Segmentation Inference
This document aims to demonstrate how to use rknn-toolkit2
on an x86 PC to simulate inference of the YOLOv5 object segmentation model without the need for a development board. For the required environment setup, please refer to RKNN Installation.
Prepare the Model
In this example, we will use a pre-trained ONNX format model from the rknn_model_zoo as an example, convert the model, and perform simulated inference on the PC.
If you are using conda, please activate the rknn conda environment first.
conda activate rknn
Download the
yolov5s-seg.onnx
modelcd rknn_model_zoo/examples/yolov5_seg/model
# Download the pre-trained yolov5s-seg.onnx model
bash download_model.shIf you encounter network issues, you can visit this page to download the corresponding model into the appropriate folder.
Use
rknn-toolkit2
to convert it intoyolov5s-seg.rknn
cd rknn_model_zoo/examples/yolov5_seg/python
python3 convert.py ../model/yolov5s-seg.onnx <TARGET_PLATFORM>Parameter explanations:
<onnx_model>
: Specify the path to the ONNX model<TARGET_PLATFORM>
: Specify the name of the NPU platform. Supported platforms can be found here<dtype>(optional)
: Specifyi8
for int8 quantization orfp
for fp16 quantization. The default isi8
.<output_rknn_path>(optional)
: Specify the save path for the RKNN model. By default, it is saved in the same directory as the ONNX model with the filenameyolov5s-seg.rknn
Run the YOLOv5 Segmentation Simulated Inference Python Demo
Install the required dependencies via pip3
pip3 install torchvision==0.11.2 pycocotools
Run the simulated inference program
- Modify
rknn_model_zoo/py_utils/rknn_executor.py
to the following code, and make sure to back up the original code
from rknn.api import RKNN
class RKNN_model_container():
rknn = RKNN()
print('--> Init runtime environment')
if target==None:
DATASET_PATH = '../../../datasets/COCO/coco_subset_20.txt'
onnx_model = model_path[:-4] + 'onnx'
print('--> Config model')
rknn.config(mean_values=[[0, 0, 0]], std_values=[[255, 255, 255]], target_platform='rk3588')
print('done')
# Load model
print('--> Loading model')
ret = rknn.load_onnx(model=onnx_model)
if ret != 0:
print('Load model failed!')
exit(ret)
print('done')
# Build model
print('--> Building model')
ret = rknn.build(do_quantization=True, dataset=DATASET_PATH)
if ret != 0:
print('Build model failed!')
exit(ret)
print('done')
ret = rknn.init_runtime()
else:
ret = rknn.init_runtime(target=target, device_id=device_id)
if ret != 0:
print('Init runtime environment failed')
exit(ret)
print('done')
self.rknn = rknn
def run(self, inputs):
pass
else:
inputs = [inputs]
return result- Modify
rknn_model_zoo/examples/yolov5_seg/python/yolov5_seg.py
line 260 to set the default value oftarget
to None
# parser.add_argument('--target', type=str, default=‘rk3566’, help='target RKNPU platform')
parser.add_argument('--target', type=str, default=None, help='target RKNPU platform')- Run the simulated inference program
python3 yolov5_seg.py --model_path ../model/yolov5s-seg.rknn --img_show
- Simulated inference results (the simulator only simulates NPU computation results; actual effects and accuracy are based on board inference)
- Modify
