Quick Start
This guide helps you get started with Radxa NX4 quickly. When used with the Radxa NX4 IO Board, it enables quick validation of Radxa NX4 features.
Product images​
The Radxa NX4 Development Kit consists of Radxa NX4 and the Radxa NX4 IO Board, and can be used to quickly validate compute module functionality.
ProductNo.ViewNo.ViewNo.View
Radxa NX4 Development Kit①Top view②Side view③Bottom view
Prepare the following hardware in advance:
  • Radxa NX4 Development Kit
  • Power supply: DC5525 power adapter (9 - 20V)
  • Boot media: onboard eMMC
  • Display: HDMI cable and a monitor
  • Input devices: keyboard and mouse (for GUI operation)
Recommended accessories
Install the system​
This section mainly describes how to install a system image to the onboard eMMC of Radxa NX4.
Important
Installing the system will completely format the eMMC. All data will be permanently erased!
Before proceeding, confirm that:
  • There is no important data on the eMMC, or you have completed a backup.
Install RKDevTool​
RKDevTool is a software developed by Rockchip for USB flashing on Windows/Linux/MacOS platforms, designed to simplify and accelerate the development and debugging process for Rockchip series chips.
  • Install Drivers
Download and extract the DriverAssistant v5.14 file.
Locate the DriverInstall.exe file and run it as administrator:
To install drivers: Click the Install Driver option
To uninstall drivers: Click the Uninstall Driver option
If you have previously installed other versions of the driver, please uninstall them before installing the new one.
RKDevTool Driver Installation
  • Download RKDevTool
Download the RKDevTool utility, then extract the downloaded file. The RKDevTool.exe is the executable program - simply double-click to launch the software.
Enter Maskrom mode​
About Maskrom Mode​
In Rockchip platform development, RKDevTool is a commonly used flashing tool. We can enter Maskrom mode and use RKDevTool to flash the firmware.
Maskrom mode is the "hardware first-aid kit" for embedded devices, enabling device recovery by directly accessing the chip's low-level interfaces.
Maskrom mode is a built-in low-level recovery mode in Rockchip chips. When the device cannot boot from any storage media (eMMC, SD card, etc.), we can use RockUSB protocol to rewrite the device firmware.
Entering Maskrom Mode​
Our board features a dedicated Maskrom button. To enter Maskrom mode, press and hold the Maskrom button before powering on the board. The system will detect the button press and automatically enter Maskrom mode.
Detailed steps:
① : Press and hold the Maskrom button
② : Power on the board using the power adapter
③ : Release the Maskrom button
④ : Connect the board's OTG port to your computer's USB port using a data cable
nx4
After the board enters Maskrom mode, you can use the RKDevTool to verify the mode.
Verifying Maskrom Mode​
On Windows, open the RKDevTool. The software will automatically detect if the board is in Maskrom mode.
If the board is in Maskrom mode, the bottom left corner of the software will display Found One MASKROM Device.
If RKDevTool reports No Device Found and Windows Device Manager shows an "Unknown device", the Rockchip USB driver has not been installed on your computer.
Install the driver first: download and extract DriverAssistant v5.14, right-click DriverInstall.exe and run it as administrator, then click Install Driver. After the driver is installed, reconnect the USB cable (or re-enter Maskrom mode) and reopen RKDevTool — the device should then be detected.
Install the system to eMMC​
This guide explains how to use the RKDevTool to flash a system image to an eMMC.
Note: Ensure the board is in Maskrom mode and properly recognized by the system.
On Windows, open the RKDevTool and follow these steps to install the system to the eMMC.
① : Select the corresponding Loader file for your board
② : Select the corresponding system image file for your board (extract the downloaded image archive before use)
③ : Choose the eMMC option as the system storage medium
④ : Check the Write by Address option
⑤ : Click the RUN button to execute all operations
⑥ : Monitor the operation progress through this interface
Disconnect the board from the PC, then power cycle the device. The system will automatically boot from the eMMC.
Boot the system​
After the installation completes, connect an HDMI display, then re-plug the power adapter to boot the system.
①: Connect the monitor and the board with an HDMI cable.
②: Power the Radxa NX4 Development Kit with a power adapter.
After the system boots normally, the power LED on the Radxa NX4 IO Board lights up green, and the status LED on Radxa NX4 blinks blue.
Log in​
When you boot the system for the first time, log in using the default username and password.
The default credentials for Radxa OS are:
ItemValue
Usernameradxa
Passwordradxa
Use the system​
After logging in successfully, you can start configuring the system and developing on the Radxa NX4 Development Kit.
